Built Engine and Greddy TT plus loads of pain.
Old Apr 20, 2006 | 09:04 AM
z350phille's Avatar
z350phille
ok il try that thx.
Old May 28, 2006 | 07:55 AM
z350phille's Avatar
z350phille
I have checked all that i can and still problems.
When i disconnect my eMan blue the car seems to settle at about 1200rpm idle, but after a few minutes it dies like with eMan installed so now fix...
I rechecked all vacums and disconnected all extra thingy´s, (boost controller)
I rechecked cables to my eMang för 8th time still connected right.
I tired another eMange blue and no change.
I lowered my fuelregulator to 40psi.
no new codes either so..
Im lost
Please try help me!
I want to ride my sweet ride
Old May 29, 2006 | 08:54 AM
z350phille's Avatar
z350phille
Any sugestions?
Well i Post a full report and all goddies i have in my engine.
*Engine Parts*
Pauter rods
Arias extreme duty pistons 9.0CR
ARP studs
Rc 650cc injektors
AAM fuelreturn kit and walbro 255 pump
Nismo termostat
Koyo radiator
Greddy TT
NKG Sparkplugs LFR6AIX-11
Unorthodox Racing FullPulley Set (Crank, Alternator, and Water Pump)
Oilpan spacer,
Crawford Plenum
Samco hoses for radiator.
Drivetrain
ATS twin carbon.
Level 2 axels from forged internals / driveshaft shop.
Im planing to remove non factory parts for testing pullys, injektors and sparkplugs to se if its makes any difference.
Any sugestions will be apriciated.
Sorry for my bad english.
Regards
Phill
Old Jul 19, 2006 | 10:47 AM
z350phille's Avatar
z350phille
a litle update again then...
Im on my first week of vecation and i finaly got some hard time with my car.
I have dismantled my greddy kit and redone it.
I found some smal leaks at the lower plenum (fixed) and fixing the smal exhaust leak by the right wastegate.
rechecked fuel system and everything is fine.
I found that cyl 1 spark plug was not looking good, changed parkplug plus moved ignitioncoil to cyl 2 for check, seems to work.
I resoldered the emanage wireing rechecked it 4 times just to be sure, found one error the rpm adapter´s ground cable was grounded in chasis instead of ecu ground, fixed that.
Vacums checked for leaks find none..
Well after al this we started the car with the basic greddy tt map, and car ideled very high 1600rpm but no míssfires and it seemed like it was runing on all cylinders, after about 45sec car just starting to jump and ces goes on p0102 + p0102 pd <-- dont know what that mean but it has to do with MAF sensor and low voltage.
I searched and i found that it chuld have with injector scaling, i will remove that next time i start the beast.
Im always open for sugestions and tips please!
Another question, i wanted to update my emanage/support tool couse i have an old version of both software and firmwire but when i do i get that i got wrong version of emanage?
What to do?
Please help.
Regards
Philip
Old Jul 19, 2006 | 02:33 PM
mistaboosta's Avatar
mistaboosta
do you have UR underdrive pulley or standart sized pulley?
Old Jul 19, 2006 | 05:26 PM
mraturbo's Avatar
mraturbo
Originally Posted by overZealous1
hey philip, i would switch to the emanage ultimate or the utec. they both will give you far better and finer control over everything than the e-blue. i would lean towards the utec for it's ability to sence knock, but it is abit more money with everything you will need. the eu's target a/f map will really help pay for it's self when it comes to tuning time though.
if you can read what the cel is, i can tell you what it means and help you figure out a fix for it.
will be going by usps today and see if i can get a cheaper shipping qoute on everything also. will message ya when i get back later tonight.
Love your pict??
M
Old Jul 20, 2006 | 02:58 PM
z350phille's Avatar
z350phille
mraturbo:
I whuld have bought a Utek if i had the money to spend
But at the moment i dont
dang almost a whole summer without my blue friend.
mistaboosta:
UR pully set are on atm.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
