Update on all Turbonetics kits..
Old Apr 18, 2006 | 07:39 AM
  #61
chimmike's Avatar
chimmike
dude, the injecn exhaust is too small for a stillen s/c vehicle, it's smaller in total volume than stock exhaust, it really is!
Old Apr 18, 2006 | 07:45 AM
  #62
MIAPLAYA's Avatar
MIAPLAYA
Hmm maybe I need to look at the Injen size again...
Old Apr 18, 2006 | 07:46 AM
  #63
chimmike's Avatar
chimmike
yeah, it's like 1.5-1.70" ID on each pipe, going from 3" to dual of that size= major bottleneck=not good
Old Apr 18, 2006 | 09:18 AM
  #64
Alberto's Avatar
Alberto
Cranky FI Owner
Guys at MRC ran an APS TT with the Injen trapping 117mph(430+whp) or so, it is very small but only flowing 3 cylinders worth of air, Id say for 430whp or less its fine. Not as bad as its made out to be....
Old Apr 18, 2006 | 09:39 AM
  #65
Alberto's Avatar
Alberto
Cranky FI Owner
I don't know if I'd agree with it being the best. From what I understand, the user interface is archaic and make's greddy's software look like a top of the line system.
Are you out to buy an engine management with a nice user interface or something that gets the job done? Who cares what it makes Greddy's or anybody elses look like the EMU cant control timing how the UTEC does-but Im sure you already knew that....
Old Apr 18, 2006 | 09:53 AM
  #66
MIAPLAYA's Avatar
MIAPLAYA
It doesn't control timing in the same fasion as the Utec no (the Unichip Q I'm referring to that is) but it can control timing yes. The Unichip should get the job done. I can't speak to the older Unichip as I have no experience with it. But the UniQ as its called has been pretty reliable so far in testing and the features are pretty trick. Bluetooth datalogging is going to be bad@ss!!
Old Apr 18, 2006 | 09:57 AM
  #67
blackend's Avatar
blackend
version Q+ it does same as UTEC do,it control the timing,and got 5 maps swtich,and you can use Bluetooth which more go for us.
Old Apr 18, 2006 | 10:06 AM
  #68
theking's Avatar
theking
we need a translator!!! more go for us?
Old Apr 18, 2006 | 10:34 AM
  #69
Gman2004's Avatar
Gman2004
The unichip Q+ does has the same functions as the UTEC does. It controls timing, has 5 maps, and can be linked via Bluetooth.
As you know it does control the timing only it does in with + or - off of what the ECU is doing and will not let you set direct timing like the UTEC.
Old Apr 18, 2006 | 10:37 AM
  #70
MIAPLAYA's Avatar
MIAPLAYA
Exactly....
Old Apr 18, 2006 | 11:40 AM
  #71
Alberto's Avatar
Alberto
Cranky FI Owner
MIA will the TN stage kits running this Unichip also come with a TN spec reflash? I doubt it, but then you get into the possible--->what if the factory ECU switchs maps on you and the timing being pulled from the ECU isnt enough? Possible issues. Ill take an old user interface and direct timing control anyday...
Old Apr 18, 2006 | 11:44 AM
  #72
MIAPLAYA's Avatar
MIAPLAYA
Alberto,
I think I already stated that I'm not here to debate the merits of each EMS. Thats for another thread. As for the ECU reflash the same map is applied to both location aside from the bad gas map so thats not an issue. The current test car is running the reflash and Unichip Q. It has not been decided finally how that is going to play out hence the reason I said its still in R&D. However, should they decide to use straight Unichip it will work similar to the current Unichip and other piggybacks that lock the data going into the ECU to keep it from changing maps over. The EU, SS, older Unichip, etc ALL do this successfully now. I did not say being able to directly enter timing is not good. What I did say is the Unichip Q CAN also get the job done and DOES offer some nice features. Again if we want to discuss the merits of each EMS we should probably start another thread.
Old Apr 18, 2006 | 12:03 PM
  #73
MI 35th's Avatar
MI 35th
OGPremierMafia
hmm well, then may need to rethink this setup then... May be looking for new idea for an exhaust then soon...
Old Apr 18, 2006 | 06:28 PM
  #74
blackend's Avatar
blackend
when i instal TN i didnt get the reflash from TN cause my car is JDM so i use unichipQ+ to tune the car and it is running smooth as slik
Old Apr 18, 2006 | 10:05 PM
  #75
MI 35th's Avatar
MI 35th
OGPremierMafia
I am so ready to party!
Old Apr 19, 2006 | 09:57 AM
  #76
NETSHARK's Avatar
NETSHARK
this reminds me when people still says Windows is better than Linux :P
don`t worry Alberto you got the best piggyback so far !!
Old Apr 20, 2006 | 08:53 AM
  #77
Ten to Four Z's Avatar
Ten to Four Z
Default Dastek Unichip?
Is the Unichip Q made by Dastek?
If it is will it have all these features:
Variable valve timing adjustment
Rev limit adjustment
Boost limit & level adjustment
Dual maps for use with different fuel grades & types
Water Injection
Nitrous oxide progressive injection
Bigger/supplementary injector handling
Variable induction control
Launch control for turbo vehicles
Full throttle gear changes
Road speed limiter removal
Speedo conversion for imports
Shift light
Idle speed stabilisation
http://www.dastek.co.uk/features_unichip.htm
Old Apr 20, 2006 | 09:07 AM
  #78
nissansource's Avatar
nissansource
Shhhhh
Old Apr 20, 2006 | 09:36 AM
  #79
buzzardmountain's Avatar
buzzardmountain
Sorry if this has been commented on already, I've missed if so. Is this "version" of Unichip still require the upfront $$$$$ to be able to tune it. My question is, would Sharif be able to tune the 1.5 when it comes out?
Old Apr 20, 2006 | 10:11 AM
  #80
Alberto's Avatar
Alberto
Cranky FI Owner
I dunno if Sharif tunes Unichip now or not...I know he does UTEC and EM/EMU...
