440cc Injector Scaling
Old Apr 20, 2006 | 03:37 AM
OldManZ350's Avatar
OldManZ350
Default 440cc Injector Scaling
I've modified the Stock Vortech Fuel System with 440CC Deatschworks Injectors and a 6 to 1 FMU.
The car runs well, but is a bit hard to start. It starts rich (1-2 seconds) then cleans out and idles good about 700RPM, the AFR fluctuates between 15.1 - 14.5 so I think that the SS box setting in those cells are fine, But could it still be to rich even though AFR is reading in the correct range at Idle ?
Any Educated Ideas.........
Old Apr 20, 2006 | 06:07 AM
q8pianist's Avatar
q8pianist
r u using e-manage ?
Old Apr 20, 2006 | 06:12 AM
OldManZ350's Avatar
OldManZ350
SS Box (Split Second)
Old Apr 20, 2006 | 07:21 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What is your fuel pressure at idle? Too much fuel pressure can cause a hard start condition, especially when the engine is warm.
Old Apr 20, 2006 | 08:27 AM
OldManZ350's Avatar
OldManZ350
Should Be what stock is 51 PSI
Old Apr 20, 2006 | 01:46 PM
q8pianist's Avatar
q8pianist
set ur idle to 850.
and your fuel pressure 48-50 at idle.
do u have cams ???
