Where to install 3 bar map sensor?
Old Apr 20, 2006 | 01:52 PM
krazE's Avatar
krazE
Question Where to install 3 bar map sensor?
Where on the 350z would it be installed? and how ? Thanks for any info.
Old Apr 20, 2006 | 03:30 PM
theking's Avatar
theking
anywhere in the engine bay with a vacuum line from the manifold. If you need these types of questions answered I hope you aren't installing a turbo kit yourself.
Old Apr 20, 2006 | 03:42 PM
krazE's Avatar
krazE
lol, because i've never seen one of these i shouldnt install a turbo kit? i've installed 2 turbo kits and 1 vortech kit.
the reason i was asking the question is because the one side of the sensor is threaded and has no cap like a boost gauge to lock in the vacuum line.
secondly, these map sensors claim to allow the stock ecu to read more boost, therefore, i didnt see how it would be possible by directly taking a hose and plugging it in the 3 bar map sensor.
Old Apr 20, 2006 | 03:54 PM
dscheers's Avatar
dscheers
Not as far as I know... and the Stock ECU uses MAF, not MAP...
Old Apr 20, 2006 | 04:16 PM
krazE's Avatar
krazE
it looks like you have zeitronix, did u install the boost sensor? if so, where/how. i mean, i could buy some type of fitting and put a hose on the threaded portion and then T a hose off the manifold pressure...
Old Apr 20, 2006 | 05:20 PM
dscheers's Avatar
dscheers
Yeah, the Zeitronix boost sensor is connected to a T in the line that comes off the plenum. My SSV has an additional bung that I'll use to connect the UTEC MAP sensor.
Old Apr 21, 2006 | 04:32 AM
theking's Avatar
theking
They mean when you already have a stock map sensor which our cars do not.
2ndchanceZ
Oct 26, 2015 08:03 PM
