spark plugs?
I just recently had my ST installed and the car is overheating. I checked all of my hoses and everything is hooked up. I found out yesterday that the shop installed stock plugs in place of one step colder plugs. I was told that this could be my problem I just wanted to ask you guys if you think that is the problem or to look somewhere else for the overheating problem.
The car goes to the tuner on tuesday and the new plugs come in on monday I just want to solve my overheating issue before it goes to the tuner. Also is there a DIY for spark plugs. My car is a 04 G35 coupe. Thanks guys
Just to add there is no SES light when it overheats or runs. Thanks
Have you checked there are no air pockets in the cooling system? I recently swapped out old coolant for new and ran hot immediately. I limped back to the shop where they re-attached what I assume was an air extractor hose and topped off coolant levels again. Problem solved.
Is there anything else I should check out for my overheating problem besides changing the plugs and checking for air in the system?
Sounds look air in cooling system.
Does your heater work? If the air is cold or luke warm, its a definate sign of air in the cooling system.
The spark plug type will not make your engine run any hotter or colder. Although I would definately recommend a set of NGK one step colder Iridium plugs for FI. http://www.forgedinternals.com/store/home.php?cat=275
How do you check for air pockets? Is it something I can do or does a shop have to do it? Thanks.
