TN Turbo+ZEETOYZ (Pi-Thon Clamps) Write-up
Old Apr 23, 2006 | 06:06 PM
vitaminZ's Avatar
vitaminZ
Default TN Turbo+ZEETOYZ (Pi-Thon Clamps) Write-up
There is some interest in this so i decided to do a write up. the Hose clamps i used were Pi-Thon clamps from www.ZEETOYZ.com. The only modfication needed was on the TN intake piping between the MAF flange and the Throttle Body flange. The clamp on the MAF flange and the clamp on the Throttle Body flange were of perfect size and the clamps tightened without any problems. The clamps over the silicone couplers and TN piping were a tad bit too big or shall i say the piping was a tad bit too small. To remedy this i used F4 tape. That is what we call it in Avonics. the name came from the aircraft it was first used on or so i am told. I am not sure what the name is in the private sector. The tape is actually quite interesting. it won't really stick to anything but itself although it adhered pretty good to the silicone. When stretched, the heat created causes it to stick to itself. it gets real tight and has tremendous heat tolerance. I lined the green line over the bead of the piping so i could place the clamp correctly over the bead alot easier. Here is a pic.
Next, place the clamp over the tape and tighten till snug. Make sure to put the side with the internal compression ring toward/on the flange. You should not be able to move the clamps back or forth or spin the clamps once they are appropriately tightened.
Voila!! You have a great looking set up!! No more ugly clamps with huge bolts protruding to the sides!! The polished clamps go extremely well with the black crome TN piping. If you have a polished OEM plenum or an SSV, your engine bay will look look leaps and bounds better after this install!
I know not every one can get a hold of F4 tape. I am not sure what other tapes out there would be good for this. Possibly 3M 33+ electrical tape or maybe a silicone coupler slightly bigger than the TN ones. Cut the slightly larger slicone coupler in half to have two and use each half to make up the differrence in diameter. Just an idea.
Close up of finished product
Pic of the whole set up
Old Apr 23, 2006 | 06:55 PM
dank311's Avatar
dank311
great looking setup Vitamin! clean engine bay.
Old Apr 24, 2006 | 07:55 AM
Three5oZee's Avatar
Three5oZee
they r a clean additive to the TN piping!
Old Apr 24, 2006 | 07:57 AM
vitaminZ's Avatar
vitaminZ
Very much so!
Old Apr 24, 2006 | 08:28 AM
blackend's Avatar
blackend
Nice One
Old Apr 24, 2006 | 08:31 AM
MIAPLAYA's Avatar
MIAPLAYA
Simply amazing Jaime. You've done some fantastic work..
Old Apr 24, 2006 | 08:36 AM
MIAPLAYA's Avatar
MIAPLAYA
BTW Jaime you have PM.
Old Apr 24, 2006 | 09:17 AM
G352NV's Avatar
G352NV
Very nice bro! I sure wish I knew if these would fit the APS intake pipe.
Old Apr 24, 2006 | 09:38 AM
vitaminZ's Avatar
vitaminZ
Give Terry at Zeetoyz a call or drop him a email http://www.zeetoyz.com/contact.htm. i am sure if you measure the internal diameter of the piping he will know if he has something for you. Either way, you CAN make it work, i had to and it turned out very well.
Old Apr 24, 2006 | 10:42 AM
dank311's Avatar
dank311
yea, if end up going with the TN kit, I might have to copy you
Old Apr 28, 2006 | 05:20 PM
vitaminZ's Avatar
vitaminZ
EnjukuRacing
Sep 30, 2015 06:55 AM
Nicky R
Sep 20, 2015 01:05 PM
