Turbo Oil Change
Old Apr 27, 2006 | 10:43 AM
G3.5T's Avatar
G3.5T
Default Turbo Oil Change
I will be doing an oil change in about 3 weeks. This will be the first oil change done after my FI install. I am planning on putting in TN SYN Oil, but I am wondering what oil filters are you guys running?
Also, is there anything else to do when doing an oil change other then the "normal" procedure?
Old Apr 27, 2006 | 10:45 AM
MIAPLAYA's Avatar
MIAPLAYA
I use the factory Nissan filter and have for the last 20+k miles...no worries there. Nothing else really to check. You could glance at the oil drain fitting and make sure theres no leak there. Aside from that nothing..
Old Apr 27, 2006 | 05:54 PM
G3.5T's Avatar
G3.5T
Cool. Thanks. Do you go for the filter at the dealer or get them online?
Old Apr 27, 2006 | 07:08 PM
MIAPLAYA's Avatar
MIAPLAYA
Usually just the dealer they're like $5
Old Apr 27, 2006 | 07:16 PM
theking's Avatar
theking
I use the Mobil 1 M1-108. I just like their filters.
Old Apr 27, 2006 | 08:15 PM
taurran's Avatar
taurran
Try the Mobil M1-110. It has the same diameter as the stock filter size, but is longer and higher capacity. Fits perfectly, too.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
