Question about newly installed Walbro pump
Old May 3, 2006 | 04:24 PM
RedondoG's Avatar
RedondoG
Default Question about newly installed Walbro pump
I just finished an install of a Walbro fuel pump but I wasn't paying enough attention when I took the OEM unit apart. Specifically there is a formed rubber sleeve that goes around the pump outlet sealing it into the plastic fuel pump housing. The rubber sleeve can be installed in either of 2 ways, with the reduced ID up (away from the pump body) or with the reduced ID down (toward the pump body).
Which way is correct?
Old May 3, 2006 | 05:29 PM
kevinapex's Avatar
kevinapex
You need to make sure the smaller goes UP, into the hole of the housing unit.
Be carefull not to tear it!! I ripped mine, not much, like 1/2 of that upper ring (small ring) I would loose fuel pressure @ high boost. You can only get it as a set with the housing from the dealer!
Old May 3, 2006 | 06:19 PM
RedondoG's Avatar
RedondoG
Thanks,
Time to take it apart again.......
Dr.Paulyy
Jul 29, 2019 07:45 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
seagrasser
Oct 11, 2015 03:27 PM
