TN and UTEC issue
Old May 8, 2006 | 05:24 PM
rs350z's Avatar
rs350z
Default TN and UTEC issue
uestion not sure if anyone has had an issue like this or any idea what it might be. I was in 5th gear at about 5000 rpms and I was about to up shift and then al of sudden my SES comes on nand flashes about six times and then goes away. any ideas???
Old May 8, 2006 | 05:26 PM
theking's Avatar
theking
Check the code. Even though the SES light isn't on, there will be a dtc code in the computer's memory.
Old May 8, 2006 | 05:43 PM
Julian@MRC's Avatar
Julian@MRC
That may be the utec picking up knock and retarding timing..It flashes the SES light on the WRX one to let you know its knocking.
Old May 8, 2006 | 05:44 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I dont think the CEL flashes to signal knock on the Z with the UTEC...check the code man.
Old May 8, 2006 | 06:32 PM
rs350z's Avatar
rs350z
how long does it stay in memory?? I hopefully be able to check it tom after work...
Old May 8, 2006 | 09:30 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I think most codes will stay for 100 start-ups after it pops up, then it will clear. Dont worry it will be there...
Old May 9, 2006 | 06:37 AM
MIAPLAYA's Avatar
MIAPLAYA
Usually a flashing code means you are misfiring at that time...
Old May 9, 2006 | 01:29 PM
rs350z's Avatar
rs350z
anybody know a good place to pick up a reader
Old May 9, 2006 | 03:57 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
eBay! I'll read it for you on Saturday.
The time it stays is dependent on the type of code.
Old May 9, 2006 | 05:28 PM
rs350z's Avatar
rs350z
read the code today..it is p0300. MIA was right random misfire. Anything I should do for this. Dave thanks for the offer on the read. I broke down figured be a good time to get one anyways.
Old May 9, 2006 | 05:41 PM
Julian@MRC's Avatar
Julian@MRC
P300, from rich,lean condition or fouled plugs...Check A/F at that load point and check plugs..
MRC MOTORSPORTS LLC.
YOUR VQ35 SPECIALISTS AND #1 UTEC RETAILER AND TUNER IN THE COUNTRY!
WWW.RACEMRC.COM
732-251-8200
Sales@racemrc.com
AIM: SALESMRC
Authorized dealers for: APS, Greddy, Turbo XS, GT-Spec, Strup, Unlimited Tuning, HeadGames and more.
On site Dyno tuning with our load based Dyno Dynamics Dyno, specializing in Uni-chip, UTEC, Emanage and LS1 Edit.
ASK about our easy and felxible financing options now available for all your automotive and performance needs!
Old May 9, 2006 | 05:54 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
It is weird that the light would flash like that from a po300. I'd bet he did get a knock event and the PO300 is a seperate issue. I'd expect the SES light may come on if you drive the car more.
Your a/f looked a little lean in places to me.
Old May 9, 2006 | 07:02 PM
Julian@MRC's Avatar
Julian@MRC
The last time I saw an SES light come on while driving and blink was when my friend blew his motor with his procharger
Old May 9, 2006 | 08:20 PM
rs350z's Avatar
rs350z
well here is my a/f let me know what you guys think...
Old May 9, 2006 | 08:48 PM
Julian@MRC's Avatar
Julian@MRC
I think I cant see it..
Old May 9, 2006 | 08:52 PM
taurran's Avatar
taurran
I can see it. Your AFR doesn't look bad. It appears to hover between 11.5:1 and 11.9:1, which is fine, but getting close to 12. If you're interested in running safe, you might want to richen it up to 11-11.5:1 depending on how much timing you're running.
Old May 10, 2006 | 01:13 AM
theking's Avatar
theking
Depending on your timing, 12.0 af may be too lean.
sherm
Apr 11, 2020 05:21 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
