Emanage Ultimate Logger Question
Old May 9, 2006 | 06:20 PM
theking's Avatar
theking
Default Emanage Ultimate Logger Question
I have the EU but have a flashed ECU. I am taking timing off the flash in higher boost to run very conservative timing. My question.....Does the logger's timing number show the outputted timing from the computer then you apply the retard to get what the timing was at that spot or does it show the timing with the retard already applied. Example say at 6000rpms it shows 17 degrees of timing and then a retard of 2 degrees. Did it output 17 degrees or 15 degrees(17-2=15)????? Sharif??????
Old May 9, 2006 | 07:29 PM
fito's Avatar
fito
On the logger, you will get the final timming. If it says 17 @6000 rpm is 17, for example, if you go on the "ign adj map" and take -2 @6000 then on the logger you will see 15@6000.
Old May 10, 2006 | 12:55 AM
theking's Avatar
theking
Thanks fito. That's what I thought.
Old May 10, 2006 | 04:23 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Exactly correct.
Old May 10, 2006 | 04:24 PM
theking's Avatar
theking
Thank you Sir. I was hoping to get confirmation from you.
Originally Posted by Sharif@Forged
Exactly correct.
Old May 10, 2006 | 05:00 PM
fito's Avatar
fito
WHAT YOU DON'T BELIEVE ME! Sharif's word is better than mine!
nahh just kidding!
Old May 10, 2006 | 06:14 PM
theking's Avatar
theking
You know I give you mad props to you and your boys for running sick times!!!! It's just good to hear it from more than one person.
nahh just kidding!
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
