Turbos: Size matching, efficiency ranges, powerband, spool, overal design
When a turbo reaches near its max efficiency range they always make more TQ than hp-look at VRT's numbers and their JWT TT kits with built blocks. Past 15psi its nothing but hot worthless air. Suit yourself though ask MIA-he will confirm maybe on a Z with cams/headwork that turbo will hit close to 500whp, but 550whp never on our motors. Lol 20-23psi...
what's so funny about that? What exhaust was the AAM car running? It's quite possible they were running a restrictive exhaust, which could also explain the high torque numbers and lower horsepower numbers....etc.
Like I said, I wouldn't take AAM as the end-all be-all of what the 60-1 can do.
Stop saying that - I dont take AAM or any shop as the end all be all shop. But I do trust Mikes word on the situation, and this has already been discussed online. Its been agreed upon that this turbo will not do much past 15psi on our Z's and that what AAM made who wise is about what your gonna get out of it. Not saying you couldnt do more, but 90whp more NEVER. Look up old threads then come back and argue. And I dont recall the exhaust the car was running for the life of me....
.5 in A/F wont make a huge difference in power-and we really cant say how conservative they tuned it because we dont know how much timing the car ran/compression etc. In the realworld that 17psi efficiency is more like 15psi which is what I have been told and what I have read somehwere on these boards. At 15psi that thing wont make 500whp.
How will the TN kit work with my HKS TD? I know I will need a reverse Y pipe...It seems like it will be fine for now, but when I plan to build the engine later down the road, I would like to use it b/c I love the looks and sound.
How is the turbo lag on build motors with lower compression?
Originally Posted by MIAPLAYA
That should work just fine as long as however creates the reverse y does a clean job on it.
GREAT! I think the HKS would sound great with turbos. I may go to Sharif to do install/tune, so I think he should be able to a great job on the reverse Y.
With a low compression motor its not turbo lag you dread its off boost response. By lowering the compression of the motor you decrease power delivery off boost. This results in a slower feeling car when not on boost but you can typically run more boost to compensate when on boost. I would run 9:1 and you should be fine.
Originally Posted by Gman2004
I have 8:8:1 compression and my car hauls *** in vacuum on the freeway. I don't think a lower compression ratio is as bad on the vq as some make it out to be.
Does anyone do any track events with their ST Z/g? I have seen a few drift guys with TT, but none with a ST yet. How would it compare to a TT for drift and road racing?
I think the ST would be a little harder to put down the power upon corner exit-not saying its not possible-surely it is, you just need slightly more finesse than some linear powerband kits like the JWT twins. When boost hits in the TN it hits HARD all that TQ comes on strong. If the car isnt straight chances are your going sideways...
Is there a definitive answer on this.. but is the JWT kit capable of 600+whp?
Also I thought Z1 Motorsports was doing the install on the modified magazine 350Z (I actually saw it at the shop) did they not tune it as well?
Many after market items are required. Run the fuel pump (Walbro 255) at 18 volts - Done with no return line. But probably a good fuel pressure limiter..
MrA Turbo - will have a magazine article.. Soon and all will be told.
( Disclaimer Here )
Cheers Amy
)This difference in the CR's is unoticeable.
-TODD
