stillen oil cooler with vortech S/c?
Old May 17, 2006 | 05:42 AM
xav_350z's Avatar
xav_350z
Exclamation stillen oil cooler with vortech S/c?
can i install install the stillen oil cooler with vortech S/c??
Old May 17, 2006 | 06:00 AM
dimebagdolf's Avatar
dimebagdolf
I don't think I've seen anyone do a Stillen w/ the Vortech. Any particular reason you want to go with that? There are other options to consider...
Old May 17, 2006 | 12:31 PM
sam-z's Avatar
sam-z
Yes You Can I Installed One On My Friends
Old May 17, 2006 | 12:39 PM
xav_350z's Avatar
xav_350z
what do u suggest?
Old May 17, 2006 | 12:40 PM
xav_350z's Avatar
xav_350z
any modifications are needed? or it will fit perfectly???
Old May 17, 2006 | 12:44 PM
THE TECH's Avatar
THE TECH
I will be using the Stillen on mine. Should work fine.
Old May 17, 2006 | 12:58 PM
sentry65's Avatar
sentry65
the burninator
I called up Z car Garage and their oil cooler kit they only sell when they do the install since each install is a somewhat custom job. They want to make sure it works the way they want it to.
I've been thinking of piecemealing together some setrab cooler parts and lines etc, but still am not sure. It'd be so much easier to just buy a kit that already has everything you need where you can just make it work one way or another
Old May 17, 2006 | 01:02 PM
THE TECH's Avatar
THE TECH
Well 350steve posted a parts list of what he used on his car. It is a nice setup and I'm sure will be less than most quality kits out there. I just didn't want to spend time trying to piece it all together. But if you are looking for a cheaper alternative, his way is DEFINITELY the way to go.
Old May 17, 2006 | 01:08 PM
sentry65's Avatar
sentry65
the burninator
350steve? when I search under that name it says that's not a valid user name.
Are you talking about Chebosto's thread?
Old May 17, 2006 | 01:11 PM
THE TECH's Avatar
THE TECH
Sorry, I wrote his name wrong. It's 350Zteve and the thread is at https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/180407-oil-cooler-install.html
Old May 17, 2006 | 01:23 PM
sentry65's Avatar
sentry65
the burninator
hey thanks man
Old May 17, 2006 | 03:09 PM
booger's Avatar
booger
The Vortech comes with a sandwich to send oil to the SC . How do you incorperate a cooler ? Do you send it thru the cooler then to the SC ?
Old May 17, 2006 | 03:19 PM
sentry65's Avatar
sentry65
the burninator
I thought you put the sandwich right next to the vortech's sandwich?
Old May 17, 2006 | 03:31 PM
booger's Avatar
booger
You would have to double them up to do it that way . Thats why Im asking , I would think you would only want to have one of them...dont know
Old May 17, 2006 | 04:26 PM
sentry65's Avatar
sentry65
the burninator
I'm running the APS pan doesn't that have an oil return line built into it?
Old May 17, 2006 | 04:29 PM
booger's Avatar
booger
The return shouldnt be a problem..no matter how you return the oil . Just wondering the best way to do a cooler with the SC
Old May 18, 2006 | 05:59 AM
THE TECH's Avatar
THE TECH
The Vortech doesn't come with a sandwich, it only comes with a tee that you use from the oil pressure sensor. You will still be able to use the sandwich that comes with the Stillen with no issues.
Old May 18, 2006 | 06:58 AM
wilric44's Avatar
wilric44
I was about to order the Stiller oil cooler with thier SC but changed my mind. It took almost four days for them to get the oil cooler parts together which seemed strange to me. DO I really need the oil cooler with thier supercharger.
Old May 18, 2006 | 07:16 AM
THE TECH's Avatar
THE TECH
Stillen has the oil cooler on backorder at the moment from what I know as of yesterday. Not sure why you think it strange about them having to get parts together. Since they don't actually manufacture any of it, they would have to order parts from outside vendors to make the assemblies.
Do you NEED it? Probably not. But, it is a good insurance item since the s/c will definitely raise oil temps.
Old May 18, 2006 | 11:15 AM
booger's Avatar
booger
I never paid much attention to it , any time Ive been under the car . I will look closer next time
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
