Turbonetics or Aps Single with Crawford headers
Old May 21, 2006 | 06:53 AM
bhk1004's Avatar
bhk1004
Default Turbonetics or Aps Single with Crawford headers
hey wuts up guys. I was at the ZdayZ tail of the dragon, which was amazing btw, and I won the raffle for a set of jet hot coated brand new crawford headers. I need to know before I install these if they will fit with either the turbonetics or aps single turbo kits. thx for any help that I can get.
Old May 21, 2006 | 07:59 AM
failsafe306's Avatar
failsafe306
I think you may want to just sell them, APS and TN both recommend using stock manifolds over aftermarket headers.
Nice prize though!
Old May 21, 2006 | 08:01 AM
bhk1004's Avatar
bhk1004
i know they both recommend stock manifolds..... but it feels like such a waste if I sell it. if it fits, id probably just install them and hope for the best ^_^
Old May 21, 2006 | 08:31 AM
savvy's Avatar
savvy
sell it and buy some other mods
Old May 21, 2006 | 11:54 AM
Osix350Z's Avatar
Osix350Z
Sell them..
Old May 21, 2006 | 12:17 PM
hypeiv's Avatar
hypeiv
stay NA or sell them... The money you get from selling them will be worth more than any gain you may or may not get from using them with those kits.
Old May 21, 2006 | 03:01 PM
thawk408's Avatar
thawk408
Just sell them if you are going single. They are also Jethot coated so you could easily get $1000 for them.
Old May 21, 2006 | 07:25 PM
D350Z10's Avatar
D350Z10
DONT SELL THEM. I am using crawford headers on my turbonetics stage 2 kit producing over 600whp, they are a solid mod. When I was with the stock tn kit I made 450whp @ 9psi with those headers most power for that kit. Just a little downpipe mod required.
Old May 21, 2006 | 08:00 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Curious as Ive never seen you post this. You had to run an agressive tune to achieve 450whp @ 9psi on the TN kit. What was your timing at redline?
Old May 21, 2006 | 08:05 PM
D350Z10's Avatar
D350Z10
The Tune to achieve that map wasn't agressive, we went to 7100 rpms and through in a little more fuel, timing was right on at redline but the power curve dropped along 6800 somthing rpms, I dont know the exacts my tuner does but it was along those lines.
My car was perfectly healthy with that map, a bad injector caused a minor problem, but was easly fixable. Just wanted more power and went with the build.
Old May 21, 2006 | 08:19 PM
Nismo180's Avatar
Nismo180
I say throw them in. It's been proven time and again that better organized exhuast pulses spool turbos better, and clear the turbine with less turbulence which leads to higher enthlapy exhuast flow(had extra power and spool time yo.). The only downside to the SS manis I could see vs the cast stockers is cracking, but the coating should take care of that.
Old May 21, 2006 | 10:11 PM
thawk408's Avatar
thawk408
Didnt you use a dynopack to get those numbers? Not trashing your numbers, but dynopacks read high.
Old May 22, 2006 | 06:30 AM
MIAPLAYA's Avatar
MIAPLAYA
The headers aside from one person have never been tested for fitment but so far I haven't seen a set of headers that made any extra power over the stock ones with either ST kit. In fact all I've seen them do is lower the boost threshold
Old May 22, 2006 | 08:38 AM
Z PHAT Z's Avatar
Z PHAT Z
+1^^ I don't see any after market headers made extra power with the TN kit except for D350Z10(Crawford). I got Stillen headers in with the TN kit and no extra power were made and spool time is longer.
Old May 22, 2006 | 09:02 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I know your pretty cool with your tuner and I know you use your UTEC-do a log and tell us what your timing looks like Im curious. "Timing was right on at redline" <----that didnt really tell me much-are you saying your using the TN flash timing map?
Old May 22, 2006 | 09:14 AM
MIAPLAYA's Avatar
MIAPLAYA
To my knowlege he never used the Turbonetics reflash when he installed his kit...
Old May 22, 2006 | 12:41 PM
dirtroad's Avatar
dirtroad
aftermarket headers are not recommended for the APS single turbo setup - had mine removed and put on the OEMs at install. the labor cost for installing headers would be several hundred alone - most places take about 6-10 hours to install headers.
Old May 22, 2006 | 12:47 PM
plumpzz's Avatar
plumpzz
Does this have a similar effect w/ superchargers? Or only turbochargers?
Old May 22, 2006 | 12:55 PM
D350Z10's Avatar
D350Z10
I never had the reflash with the utec tune, I am going in for another tune this week sometime and will log it and print it off, From experience and performance I can tell you first hand it is a good soild mod, the spool time is nothing it was like 200 rpms more so thats not even an excuse, I am just saying if you want stand out power go for it.
Old May 22, 2006 | 01:31 PM
thawk408's Avatar
thawk408
I think I recall that you had to have a custom downpipe made to clear the crawfords. Is that correct?
