Our theory on stock rod failure...
Old May 31, 2006 | 10:17 AM
  #61
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by MRC Motorsports
I explain to all my customers before hand that anytime you double the output of an engine on stock parts, their is a better than 50% chance something can and will go wrong. There are no fool proof solutions. Now we have installed dozens of TT kits and this being our first failure we witnessed.We have several TT cars that have 10-35,000 miles on their turbo kits thus far problem free.i guess its just hit or miss..
Absolutely. I never posted up info like this because as mentioned, I don't have real life experience with F/I.
But clearly this is the point I am trying to convey. Go to a good shop, get a good clean install and tune, then hope for the best. But prepare for the worst, because "the worst" could happen to anyone.
Old May 31, 2006 | 10:29 AM
  #62
HoldThisForMe's Avatar
HoldThisForMe
are the rods cast? not all cast are the same. could just have been an inconsistancy in the casting of the rods that weakend them and with the added power it was just to much for them...
Old May 31, 2006 | 11:32 AM
  #63
MIAPLAYA's Avatar
MIAPLAYA
Based on what you posted the Revup car was running a single turbo kit with a reflash for a tune and did not snap the rod. You also mentioned this single turbo kit used 380cc injectors, has an overboost pipe available but not installed, and was running lean. My question is this. The single turbo kit you refer to is not released in any way shop or form for the revup motor and no flash exists for that ECU via the company that produces that kit. So how was this even possible?
Old May 31, 2006 | 12:18 PM
  #64
Oleg's Avatar
Oleg
Default Time for a new car.
MRC, thank you for making me all too painfully aware that there is no safe FI on stock block. Dropping 7500$-9000$ into a motor while having another 6000$-7000$ on standby just in case this motor blows is:
a)Way too expensive.
b)Not cost effective considering other car options on the market.
Time for a new car...
Old May 31, 2006 | 01:13 PM
  #65
TTRANK's Avatar
TTRANK
Wow this is one depressing thread. I am having second thoughts about going to Stage 4 now...
Old May 31, 2006 | 01:27 PM
  #66
Nismo350ZRT's Avatar
Nismo350ZRT
I don't find this depressing at all. Hopefully, as more and more information is accumulated from the blown motors, we'll discover the cause and the solution. I can't wait to finish up my install.
  #67
chimmike's Avatar
chimmike
hasn't rod bolt failure occurred to anyone? Just curious.
Old May 31, 2006 | 01:28 PM
  #68
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's only depressing if you missed the part where they said they have installed dozens of turbo kits but only had 2 fail.
Old May 31, 2006 | 01:41 PM
  #69
gatti-man's Avatar
gatti-man
What car would that be?? Lets say I spend 20k on my car in mods and I paid 26k new for my z. That's 46K, what car sub 60k could compete with the FI z I would now own? none imo. the vette is the only thing that comes to mind and I'd far prefer a custom car to an oem fast ride.
Old May 31, 2006 | 01:53 PM
  #70
doug's Avatar
doug
1 failure.. they didn't install the Single Turbo Kit
Old May 31, 2006 | 01:56 PM
  #71
Julian@MRC's Avatar
Julian@MRC
Actually I must correct myself....
one that bent the rod was a rev up, the one that snapped was not a rev up..The rev up had a reflash for tune and the non rev up had a piggyback Uni-chip.
Correction to my post...BOTH motors were non rev up motors..Jimmy's motor was a Rev UP motor..I have so many motors in my shop I get confused..
However regardless of the kit on the car or the motor (which the rev up is no stronger than the non rev up anyway) there was rod failure either from Hydrolicing or exceeding the mechanical limits of that particular rod..A massive boost spike would also have done what happened on his car, however, we did not do the install, nor do we know the conditions at the time of failure..I also do not know why he did not have the additional part required with that kit to avoid overboosting,perhaps he bought it online from an inexperienced online store that does not do installs..I can tell you one thing, had he come to my shop in the first place he would have been informed of the additional parts required on the kit, as well as the the fact that the injectors on that kit are way to small and the ecu reflash is a pile o' azz...Had he been running larger injectors with a UTEC that has KNock retard as well as overboost fuel cut, most likely he would not be rebuilding his motor right now..
Old May 31, 2006 | 02:00 PM
  #72
Wholey Smokes's Avatar
Wholey Smokes
It seems like every time I finally decide to buy a kit and turbo my Z, a thread about blown motors is posted, which consequently spooks me out of making the purchase. I have turbocharged the **** out of Hondas (more than doubling power output on stock blocks) without ever a problem. I am by no means an expert when it comes to FI or motors but I do have some limited experience.
I just find it hard to believe that that much coolant is making its way into the cylinder all at once. I would think there would be some type of precursor symptoms. What happened to the days when detonation was the biggest enemy and blown headgaskets/ white smoke would alert you to problems before they got too expensive? Well, anyway, thanks for posting this MRC. Now, all you vendors get on this and find a solution so I can give you my hard-earned money without feeling bad about it.
Old May 31, 2006 | 02:06 PM
  #73
Julian@MRC's Avatar
Julian@MRC
Were not 100% sure that the head lift issue is what caused it..It also could have been weak rods in the first place..Its really hard to say with 100% certainty..
Old May 31, 2006 | 02:19 PM
  #74
sentry65's Avatar
sentry65
the burninator
hehe a modded STI or EVO come to mind
yeah I agree with you though except having a warrenty is nice, though still a headache fighting with dealers to fix stuff that isn't your fault that it broke
  #75
rookie's Avatar
rookie
Stage 4 is probably safer than stage 3, the upgraded fuel pump and injector alone are worth it. Not to mention the updated split second map.
Old May 31, 2006 | 02:21 PM
  #76
Havok_RLS2's Avatar
Havok_RLS2
Thats because you have a A1 shop. You'd be surprised just how many shops don't give there customers that information. Some shops just wanna sell a turbo kit and collect the money on the install.
  #77
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I stand corrected, but the sentiment is the same
Old May 31, 2006 | 02:35 PM
  #78
Havok_RLS2's Avatar
Havok_RLS2
I know how you feel.
I also had a 92 honda civic with fully built B16A(from Pann Motorsports) that I had turbo(Greddy intercooled) and 100 shot direct port Nitrous back in my ricer days (before the term "ricer" exsisted). The I got my first 93 300zxTT with JWT ECU, HKS catback, and single wet system ZEX kit.
Guess which one I blew the motor in first?
Old May 31, 2006 | 02:43 PM
  #79
sentry65's Avatar
sentry65
the burninator
well we all know honda engines are over engineered
Old May 31, 2006 | 02:46 PM
  #80
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
taurran has it spot on.
The root cause of this is probably not something you'll easily be able to diagnose, nor is it something you can likely prevent. Bottom line is you are introducing boost to a car that was not designed with boost in mind. As such, things can, and do, break. Some cars will be lucky and never experience an issue, others will experience problems. The only surefire way? A motor built by a reputable machine shop, using quality components, and a good tune.
I've seen the same thing happen on nearly every import motor out there that was ever turbo'd or SC'd and not built, and I've gone through it myself on personal cars. Best example is my '99 2.5 RS, which I got new back in '98. Myself and a friend turbo'd our cars, and for whatever reason, were able to run more boost, on a daily basis, with merely piggybacks, where others were blowing motors with standalones and less boost. At the end of the day, you find that cars are like fingerprints in that no 2 are the same. Some get lucky (as I did, eventually being able to run 18-19 psi of boost on a bone stock 2.5 RS with nothing more than a cheesy rising rate fuel pressure regulator, big fuel pump a SAFC and an ITC running things), and others find out that building a motor, while a financial burden, is the only way to truly prevent things from going boom.
