vortech or ati procharger
Old Jun 1, 2006 | 05:22 PM
Mr_pharmD's Avatar
Mr_pharmD
Default vortech or ati procharger
I'm having a hard time deciding on which sc to go with and any input would really help.
I'm looking for something around the 370-380hp /310 tq (nothing crazy) but something reliable for daily driving. I was leaning toward the vortech for the longest time BUT I have been seeing more complaints with this kit everyday (rattle at idle etc.).
I have heard that the procharger is suppose to produce more hp/tq when compared to vortech but I haven't been able to find any dynos showing more than 350hp with this kit.
So, which kit should I go with if I want ~375hp/310tq???
This will be for an AUTO 05 g35 coupe with alpha headers, borla exhaust, and kinetix cats and will be adding unichip, walbro fuel pump, pe 380cc injectors as the fuel mangement.
Old Jun 1, 2006 | 05:57 PM
bobstaff147's Avatar
bobstaff147
I've just been through the same process and I decided on the Vortech.
I did not see a significant number of extra problems mentioned in the various forums about the Vortech vs ATI. Do you have some links to sites with numbers of problems with each system?
One major factor for me was that the ATI has its own oil and to change it one a 350Z apparently you basically have to dismantle the system. On the Vortech you just change the engine oil.
I just got my kit today from JEGS and unfortunately the intercooler was damaged, JEGS are going to replace it which is good, but I'll have to wait a while before installing it.
Old Jun 1, 2006 | 06:39 PM
Mr_pharmD's Avatar
Mr_pharmD
thanks for the input. keep me updated if u can.
Old Jun 1, 2006 | 06:42 PM
booger's Avatar
booger
Some things to think about .
The ATI [ I havent heard one ] Is supose to be much louder whine .
ATI has a self contained oil system . You change oil by sucking it out . ATI has a tool to do it with.
The full Vortech kit will get you exactly what you want with out adding fuel injectors , fuel pump , or new EMU . Your better off using the Utec than the Unichip . The SplitSecond box is just fine for the power level you want .
IMPO your wanting to spend money for stuff you will not need at the power level your looking at
Old Jun 1, 2006 | 06:50 PM
Mr_pharmD's Avatar
Mr_pharmD
I'm not sure if I trust the fmu setup with stock injectors when i'm running the 3.12 pulley. Wouldn't it be safer with a better fuel setup like injectors and unichip (pull timing when needed)? I would have gone with something else but I only know 1 place near my area that deals with unichip.
Old Jun 1, 2006 | 07:11 PM
booger's Avatar
booger
Vortech wouldnt have done the fuel system that way if they didnt think it would hold up over time . Of course there are better ways including the one you are thinking about .
Old Jun 1, 2006 | 07:58 PM
THE TECH's Avatar
THE TECH
One thing you can think about is that the Vortech is CARB legal whereas the ATI is not. Since you are in CA, like me, it may be something worth considering.
Old Jun 1, 2006 | 08:22 PM
Mr_pharmD's Avatar
Mr_pharmD
i thought it was 50 states legal?
Old Jun 1, 2006 | 08:44 PM
k3silk's Avatar
k3silk
i have heard both kits in person and i will say that both are loud! but as for the vortech and the A.T.I i would choose the vortech for some of the reason stated above. CARB+
Old Jun 1, 2006 | 10:19 PM
sentry65's Avatar
sentry65
the burninator
you think the ATI won't rattle at idle like the vortech would? If anything it'll whine a lot louder
the ATI is not CARB legal as of right now, but maybe someday
I think the ATI is a great kit. Both will get you 370-380hp and 310tq easy if you have the right breathing mods.
The belts on the ATI will still stretch, but they won't slip at least.
Old Jun 2, 2006 | 06:05 AM
superchargedg's Avatar
superchargedg
Damn Noobs
ive heard both and the ati is louder,id go with the vortech.and you also have booger and sentry who can answer a lot of your questions.
Old Jun 2, 2006 | 06:12 AM
RBALDINELLII's Avatar
RBALDINELLII
I have the Procharger, and it was loud as hell when it was new. It was crazy. But now after 15K miles of daily use, it's very quiet. Can't tell you why that is, but at an idle now, you really have to listen for it to hear it. As for the oil, I don't know how everyone else does it, but I just loosen up the drain bolt on the bottom of the unit and let it drain out on to a rag. Its only 4 or 6 oz. Not as much as you would think.
Old Jun 2, 2006 | 06:27 AM
xav_350z's Avatar
xav_350z
i ordered the vortech and install it soon.
can i go with the 3.12 pulley on stock engine?without any modifications?
Old Jun 2, 2006 | 10:25 AM
leemik's Avatar
leemik
Yo Rob, mine still whines as loud as the day i bought it.. at first i hated it but the car looks so aggressive now that the sound sort of matches the look.. so i don't mind anymore..
as for the oil change, ATI charges you $20 (used to be free) for this turkey baster type contraption that sucks the oil out from the screw on top.. takes me about 5-10 mins to change my oil
--mike
Old Jun 2, 2006 | 10:34 AM
sentry65's Avatar
sentry65
the burninator
the oil thing to me is a moot point - every other FI kit there is for the Z uses the engine oil for cooling - or in the case of the APS turbos also use the coolant in addition to engine oil
Old Jun 2, 2006 | 11:30 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
From our experience, the ATI tends to eat belts much faster than the Vortech. The ATI uses a lightened billet aluminum mounting bracket, and it has quite a bit of flex in it. The Vortech is more rigid. As such, as the ATI spools, the belt alignment becomes an issue, and it eats more belts.
My vote is for Vortech tuner kit, with return fuel system, UTEC, pressure sensor, and a walbro pump...coupled with 440cc injectors.
Old Jun 2, 2006 | 12:04 PM
sentry65's Avatar
sentry65
the burninator
and there's two belts to replace with the ATI instead of 1 longer one with the vortech
I think for most people at moderate whp levels, they'll be roughly equal with maintenance. I chose vortech as most people getting a centrifugal have
Old Jun 3, 2006 | 04:09 AM
gmoney7770's Avatar
gmoney7770
LOL, Sharif you just described exaclty what i want....u got a price for that, lol
Old Jun 3, 2006 | 11:01 AM
k3silk's Avatar
k3silk
its called you got used to it!!! J/K
Old Jun 3, 2006 | 01:45 PM
Eagle1's Avatar
Eagle1
I had the ATI. Initial set of belts went 18,000 miles before I lost the smaller cog belt. It simply stretched over time, and I was not diligent in keeping the tension. Other than that one item, not a single issue with the unit. Got 23,000miles on it and then went tt as my orientation became more track directed. Avo has the unit, upgraded the kit, and is bopping around town like Top Gun.
It sounded like an F-18 on approach for a carrier landing. I would not say that it was louder or quieter than a Vortech, and I have heard plenty of both brands. They are fundamentally the same basic units, centrifugal superchargers. One has a self contained oil reservoir and the other taps the oil pan.
What is going to matter is how you set up the engine management and fuel system and tune it.
