Turbo rusting...
Old Jun 13, 2006 | 10:15 AM
  #41
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by DBZ33
I want one asap. The page below says that the black blanket will fit a T-72 and smaller. "The black blanket is slightly smaller and we know it fits T-72 GTQ and smaller, we have not tested it on anything bigger."
Do you think it will fit out T-60?
Yes. We don't have a T-60 but we do have a 60-1 compressor and a Stage V turbine with a .77 A/R KK housing tangential. That all being said get the silver one...The cheaper one looks too cheap...get the one luci got...
Old Jun 13, 2006 | 10:27 AM
  #42
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks for the pics. How hard was it to put in? I assume the MAF and higher piping needs to come off or can you sneak it through...
Old Jun 13, 2006 | 10:45 AM
  #43
lucidazn's Avatar
lucidazn
I had to disconnect it from the throttle body, and the bolt that holds the BOV pipe on the front of the engine. For some reason, I wasn't able to pull the BOV pipe off. It was stuck inside the rubber hose after undoing the clamp.. But I was able to slide the pipe up the rubber hose 2 inches to give me clearance for the blanket. Simple install, 30 minutes if you have the right tools.
Edit: On another note, after this install, the BOV pipe will be resting on the blanket! I don't anything bad can happen from this. Just letting you know.
Old Jun 13, 2006 | 11:26 AM
  #44
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks for the info man...
bcoffee20
Nov 19, 2015 06:39 PM
