how come I can't find any ST dynos that start at 2000 rpms?
Old Jun 10, 2006 | 06:33 PM
tig488's Avatar
tig488
i also have the blitz controller, you can set the gain real high and the boost climbs like a banshee, it goes from 1 to 12 in a split second, or you can turn it down for a slower build, its pretty cool.
Old Jun 10, 2006 | 10:49 PM
plumpzz's Avatar
plumpzz
whoa, joe dirt how come your st spools so slow? It uses almost the same sized turbo as TN. 4200RPM it looks like, if im reading it right.
NVM, only taurens spools like that . And the scaling fooled me.
Old Jun 11, 2006 | 03:53 AM
taurran's Avatar
taurran
Remember that just because your power levels off at 4000 rpms doesn't mean that's when you reach full boost. Just like an NA car, you will still continue to build power as RPMs rise. I think many of these people build full boost well before 4000 rpms, and the dyno sheet is a bit deceptive.
Old Jun 11, 2006 | 06:22 PM
tig488's Avatar
tig488
^^what he said
Old Jun 12, 2006 | 09:54 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Depending on how the operator starts a load based dyno, the boost curves and trq buildup can vary dramatically. One trick that some shops use, is to load up the engine, and generately nearly full boost, then release the dyno. The results is a massive trq spike and boost buildup at very low RPM. We dont do that, becuase it not indicative of a real world trq curve.
This trick is not possible with a non-load based DynoJet, FYI,
And you guys are right...different types of boost controllers and settings, can result in different boost curves.
Old Jun 12, 2006 | 09:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Sharif-so some of these TQ happy JWT dyno's could be guilty of that huh?
Old Jun 12, 2006 | 10:04 AM
done12many2's Avatar
done12many2
Ouch
Old Jun 12, 2006 | 09:02 PM
Weqster's Avatar
Weqster
Comparing dyno's are useless. i could make my NA 350 put down 400whp! They are a tuning tool guys :P
Old Jun 13, 2006 | 09:03 PM
taurran's Avatar
taurran
I'm pretty sure everyone knows this, so that didn't really contribute anything.
They do give a GENERAL idea of power output and also power delivery (area under the curve), so you can't say they are completely "useless".
Old Jun 13, 2006 | 09:12 PM
sentry65's Avatar
sentry65
the burninator
Different dynos in different locations are different, but you can still compare a graph to itself. You can look at 3000 rpms and 4000 rpms and note if there's a difference of 40tq or 80tq or what % increase it is and compare that to your own dyno chart in a relative way.
and then there's also equations to factor in elevation and the approx ambient temp difference that you can use to help kinda normalize graphs somewhat.
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
pslamp32
Feb 8, 2017 09:07 AM
AbyteZero
Sep 22, 2015 09:17 AM
FromGtoZ
Sep 20, 2015 03:41 PM
