UTEC OPEN LOOP Problem
Old Jun 25, 2006 | 02:33 PM
  #61
mistaboosta's Avatar
mistaboosta
what does that make PSI wise?
Old Jun 25, 2006 | 03:08 PM
  #62
35ounces's Avatar
35ounces
03 CS Track 6MT
Vac is not measured in PSI. do you have a gauge?
Is your UTEC MAP Sensor coming from the same source as the boost gauge?
Old Jun 25, 2006 | 03:20 PM
  #63
Julian@MRC's Avatar
Julian@MRC
Seriously dude, and Im not being an ars, but get your car to someone who knows what their doing ASAP!! Your gonna blow your zhit up man..
Old Jun 26, 2006 | 12:48 AM
  #64
mistaboosta
yes it is coming from the same source as boost gauge.
My utec is reading vacuum in PSI so that's what i'm talkin about.
I got a defi gauge and it's reading -0.65 kPA @ idle.
Old Jun 26, 2006 | 12:57 AM
  #65
mistaboosta
thanks for your concern man honestly, but i've been tuning my cars myself for 3 years and never blew anything.
Old Jun 26, 2006 | 05:45 AM
  #66
35ounces's Avatar
35ounces
03 CS Track 6MT
Utec values show standard in/HG for vac and PSI under boost.
Old Jun 26, 2006 | 01:13 PM
  #67
mistaboosta
what about this then ?
Old Jun 26, 2006 | 03:09 PM
  #68
35ounces's Avatar
35ounces
03 CS Track 6MT
that pic and a buck will get you a l$1 ottery ticket. I have compared the map values to my boost/vac gauge and they are dead on.
Old Jun 27, 2006 | 03:48 PM
  #69
aalzuhair's Avatar
aalzuhair
Just in case you want the formula
1 inHg = 0.49115415184865 psi
1 psi = 2.036020659168 inHg
Old Jul 2, 2006 | 05:45 AM
  #70
Audible Mayhem's Avatar
Audible Mayhem
My350z
hey guys, thanks for the map calibration spreadsheet.
i got the TT running utec just fine, no problems, the boost is just a little bit off from the map sensor but im sure the SS will take care of that
thanks!!!
Old Jul 2, 2006 | 04:44 PM
  #71
KPierson's Avatar
KPierson
Two things,
I think I fixed my problem with the UTEC kicking in too early. I didn't have the MAP threshold value set right in the Open Loop Fueling options. I had it set to scale from 2-20psi in the other screen (I forget which one) but I had the open loop fueling value set to 0.
Also, it appears that the MAP sensor does in fact read vacuum in PSI, not in In/Hg. I notcied my vacuum displayed on the UTEC was roughly half of what my guage showed (~-9 on UTEC vs -20 on guage). I know this doesn't matter, but it was mentioned at one point. Next, I need to use the spreadsheet and calibrate my MAP to the numbers on my card.
Old Jul 2, 2006 | 05:13 PM
  #72
Julian@MRC's Avatar
Julian@MRC
Originally Posted by KPierson
Two things,
Just like I thought....99.9% of the time when there is a UTEC problem or bug, it is user error..
Old Jul 2, 2006 | 11:49 PM
  #73
mistaboosta
i'm sure that it's less than %99.9 when it comes to Z-UTEC.
Old Jul 3, 2006 | 05:54 AM
  #74
35ounces's Avatar
35ounces
03 CS Track 6MT
Two things,
Thats weird. Mine seemed to be dead on with what my gauge was reading. I'll have to re-check that now.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
