rods and pistons??
Old Jun 21, 2006 | 06:54 PM
faster than u's Avatar
faster than u
Default rods and pistons??
i know everyone has asked this million times before but cant find what im lookin for but im going TN kit, since people are blowing their motors should i just go ahead and do rods and pistons to be safe and run more boost ????
not really sure how much this would be so maybe you guys can give some some tips.
Old Jun 21, 2006 | 06:57 PM
MIAPLAYA's Avatar
MIAPLAYA
I wouldn't say you have to build it right now no. FYI I've got 30k miles on my car with the kit and 50k total.
Old Jun 21, 2006 | 07:05 PM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
If you are interested in what I'm doing, I'm getting my kit installed over the next week or two. I am going with Turbonetics also, aam fuel return, UTEC, 550's and some other little stuff. I'm going to run stock psi, stock rev limit, and a very very conservative tune. Looking for around 375rwhp.
My hope is to make it till December haha. I dont think you need to build right away as long as you are conservative. I could do the build now, but I would rather wait a couple months so it wont be such a dent in the bank account.
It just depends on how much risk you want take. From what I have been reading, and I've been doing a lot, it tends to be the people that go over the stock hp levels of the kit, raise their limiters, and just basically go with an agressive tune overall that blow up first. I mean look at MIAPLAYA, hes running the stock boost, sitting around 380rwhp and no problems at all.
But then again you have the guys that get away with it like Taurran who is over 400 on the stock motor. Like everyone else has said, its 50/50 toss up, but I certainly believe to can sway the odds on your side the more conservative you go.
Derek
Old Jun 21, 2006 | 10:06 PM
faster than u
see the thing is i want like 415 hp, i want to break 400's and i will be happy, i figured if i do rods and pistons i can run more boost and it will be safe, and make well over 400 easy
Old Jun 21, 2006 | 11:25 PM
kosmic's Avatar
kosmic
For "just" doing rods & pistons, can't you drop the oil pan & crank and put them in from the bottom so that the whole motor doesn't have to be pulled? Seems like a good cost compromise for more safety.
Old Jun 22, 2006 | 01:08 AM
G3.5T's Avatar
G3.5T
Intresting. I would like to know how much that would run as far as labor.
Old Jun 22, 2006 | 06:25 AM
MIAPLAYA's Avatar
MIAPLAYA
IIRC that is not possible with our motor...
Old Jun 22, 2006 | 07:25 AM
USED's Avatar
USED
Please think about what your saying here. Your planning on spending about 2G on pistons/rods/bearing/etc and you want to put them in your engine in the car. You will not measure/inspect/hone (emphasis here). Your gonna just slap the new parts in? IMHO a complete waste of money/time/effort.
It's not a honda accord your trying to sell for a quick buck. Anyway, it can't be done in the car. Way too many obstacles.
Old Jun 22, 2006 | 09:49 AM
kosmic's Avatar
kosmic
Yea, after I made that post I started thinking about the "reality" of doing it like that and I figured I'd probably get flamed for even posting it. Thanks for being nice.
Old Jun 22, 2006 | 04:58 PM
faster than u
wtf, well i thought it was a good idea too, i still would like to know the cost of doing that, i want to have like 420hp knowing everytime i wot it wont blow up
Old Jun 22, 2006 | 05:31 PM
Weqster's Avatar
Weqster
U will need to remove the heads as well. I never tried with the 350z, but heads and pan and u can slap it together incar. But it think u may find that the extra labour/work involed working within the restricted confines means the labour costs may equal that of a pulled engine.
The idea is sound though. on a fresh motor u can defaintly get away with a hone, and just installing rods pistons (always check piston->wall clearance)and rod bearings. THis would be super safe 450whp.
Old Jun 27, 2006 | 11:19 PM
faster than u
thanks , im going to find out from japtrix and see how much they can do this for, i just want to be safe
Old Jun 28, 2006 | 01:35 AM
S12 driver's Avatar
S12 driver
If you have an engine crane you can just pull the engine yourself, and leave the built to the professional. That way you would save quite a bit of labor, but leave all the internal stuff that requires precision to the pros.
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
B Esquire
Sep 24, 2015 07:52 AM
