APS TT Stalling
Old Jul 3, 2006 | 11:24 PM
Richard Z's Avatar
Richard Z
What I am getting is stalling when I let off the clutch over 2500rpm and rev then engine at idle. The idle is set at 850rpm and idles fine at stand still.
Do any off you have any other thoughts on this as I am at a loss.
Old Jul 3, 2006 | 11:37 PM
Ahmads350z's Avatar
Ahmads350z
never heard of that...
Old Jul 5, 2006 | 03:53 AM
jpc350z's Avatar
jpc350z
Do you have a light flywheel. I do and had similar problem.. Not enough momentum in the flywhel and it drops very fast..For some reason the problem seems to have gone away for the most part. Very occassionally it comes back but knowing of its potential I rev it when shifting or on quick slow down's..Do you have a vacuum gage. What is it doing when it is stalling?
Old Jul 5, 2006 | 07:57 AM
bigbri's Avatar
bigbri
You know whats funny is I had this problem also right after I had my new setup put in...Like said eairler in this post you ecu needs to relearn your idle..how many miles have you had the new setup..mine took about 1300-1400 miles before it stoped...
Old Jul 5, 2006 | 08:34 AM
jpc350z's Avatar
jpc350z
Didn't keep track of when it stopped but stop it did.. Maybe something to the learning theory..Damn smart *** computers..
Old Jul 5, 2006 | 10:42 AM
Richard Z's Avatar
Richard Z
The only thing I have done to the car is put the APS TT kit on it.
It dose seem to be getting better saying that. I have only done 2 to 3 hundred miles in it.
Old Jul 15, 2006 | 11:59 AM
Richard Z's Avatar
Richard Z
Hi
A quick update I have done a good 2k and the dam thing is still doing it. Do any off you have a clue off what this can be as I am at a loss.
Thanks
Old Jul 24, 2006 | 04:49 PM
azn_speedracer's Avatar
azn_speedracer
my 350z w/ greddy tt does it also
Old Jul 25, 2006 | 01:00 AM
Richard Z's Avatar
Richard Z
Do any off you think it could be the MAF ??
Old Jul 25, 2006 | 06:36 AM
Noah@AAM's Avatar
Noah@AAM
I have had this issue as well....i did the JWT fix, worked for a month then i experienced stalling again. Mine only stalls after the first time i get it over 3K rpms. Even if on the hiway, i need to restart the car. Raise the idle to 900 and it should be solved. Mine still dips but no longer stalls.
Old Jul 25, 2006 | 06:46 AM
Richard Z's Avatar
Richard Z
HI
i have had the idel raised to 850rpm but is still doing it ?
Old Jul 25, 2006 | 07:22 AM
jpc350z's Avatar
jpc350z
Originally Posted by Richard Z
HI
Maybe time to do the 1/8 in. hole drilled into the throttle plate that several posters have said works..Might wanna do a search. Good luck
Old Jul 25, 2006 | 09:15 AM
Noah@AAM's Avatar
Noah@AAM
i would avoid drilling a hole in throttle plate...Jim Wolf's fix achieves the same results but without the risk of messing up your throttle plate....try driving with the A/C on and see if it still stalls....the A/C will allow you to theoretically raise the idle another 150-200 rpms when turned on....if it still stalls you need to look into other things such as the Jim Wolf Fix...if it fixes it then you need to raise the idle
Old Jul 25, 2006 | 09:19 AM
jpc350z's Avatar
jpc350z
Many posters have said the JWT fix doesn't and those who did the drilling were satisfied..Check the search for more qualified responses..
Old Jul 25, 2006 | 10:00 AM
Noah@AAM's Avatar
Noah@AAM
it worked for me and I am only sharing that experience. not knocking those who drilled for that I know that works as well.
Old Jul 25, 2006 | 11:50 AM
Richard Z's Avatar
Richard Z
Noah@AAM do you have photo you can post so i can see what and where the hoses conect up please.
Thanks
Old Jul 25, 2006 | 02:23 PM
captj3's Avatar
captj3
Did you try to contact peter at aps? He is more than willing to help if he can. I've had a good experience with him helping me with the kit. Either e-mail him or pm him on 350z motoring. com
Old Jul 26, 2006 | 06:33 AM
  #38
Noah@AAM's Avatar
Noah@AAM
i will take some and post them up when I have a chance....
Old Sep 15, 2006 | 08:12 PM
  #39
brooke's Avatar
brooke
My car is now doing the exact same thing. I have yet to find the problem but I'm guessing it is a small vacuum leak or a bad 02 censor..
brooke
sherm
Apr 11, 2020 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
foxsmp26
Sep 25, 2015 09:48 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
Darkspy
Sep 7, 2015 09:09 PM
