Any TN ST owners plan on switching from T60 to T66?
Old Jul 5, 2006 | 10:55 PM
  #41
Oleg's Avatar
Oleg
Someone is wondering about TN ST's "not making a lot of power" (must be someone with a Supra syndrome). Here is a very simple explanation, and it has nothing to do with PSI, or CFM or whatever. Just basic mentality. There seems to be a very popular belief here that twins are the way to go. A lot of ST users bought what they did b/c of price difference. Not everyone could or wanted to pay a 3-3.5K premium to get a TT kit. So if the price difference is an issue, who do you think is more likely to build the motor? Hence the relatively low # of ST users throwing big hp around. Majority of people who werein the market for FI and a built motor ended up going with twins.
Old Jul 6, 2006 | 04:05 AM
  #42
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by MIAPLAYA
The Modified Mag Turbonetics powered Z is running 14 PSI...Max boost within the efficiency island is 26 PSI on the 60-1 compressor. On a T66 its more like 32 PSI...
What? I thought the 60-1 just blows hot air past 15psi or so...
Old Jul 6, 2006 | 06:34 AM
  #43
MIAPLAYA's Avatar
MIAPLAYA
Its loses efficiency rapidly past 15 PSI. The compressor wheel sweet spot is at or around 15 PSI. It is capable of pressurizing air up to 26 PSI while still being on the efficiency island but the efficiency of the compressor has dropped drastically at that level...
Old Jul 6, 2006 | 06:38 AM
  #44
Alberto's Avatar
Alberto
Cranky FI Owner
So what a turbo is capable of pressurizing doesnt really matter if it cant do it efficiently then correct? Kinda threw me off as you first said said the "efficiancy island is 26psi" then you said "it loses efficiency rapidly past 15psi"
Old Jul 6, 2006 | 07:06 AM
  #45
MIAPLAYA's Avatar
MIAPLAYA
Correct. The max compression a specific wheel can actually compress to and what it can compress to efficiently is two different things. While the turbo can make 26 PSI it would be done very inefficiently and end up casuing the air to be heated far more then it should. Roughly 18-20 PSI is the highest the 60-1 wheel will compress and maintain the higher efficiency band. After that the drop off is pretty severe. At 26 PSI its in its least efficient band...
Old Jul 6, 2006 | 09:19 AM
  #46
bverschage's Avatar
bverschage
subscribing
Old Jul 6, 2006 | 10:01 AM
  #47
nissansource's Avatar
nissansource
Id totally skip out on a AVCR and get the Blitz SBCID i hate the AVCR functionality is to much just need something that contorls boost rock solid get blitz im running it on my Big HP SRT4 ROCK SOLID BOOST AT 30PSI no spikes
Old Jul 6, 2006 | 04:34 PM
  #48
Blake350z's Avatar
Blake350z
is 500-540whp possible with a built ST running 15psi?
Old Jul 6, 2006 | 04:35 PM
  #49
MIAPLAYA's Avatar
MIAPLAYA
On the Stage 1 turbo its possible but boost pressure will probably be a bit higher then that. More like 15-18 PSI.
Old Jul 6, 2006 | 10:53 PM
  #50
D350Z10's Avatar
D350Z10
Actually with a t66 at 15psi it made 485whp safe and 17 hits 500whp we dynoed the car. On the stock t60 it will be very hard and not nearly as efficent.
Old Jul 7, 2006 | 11:37 AM
  #51
veilside350zTT's Avatar
veilside350zTT
I plan on running the T76 on my new setup.. Im just gonna keep the T60 for the break in period.. Im gonna try and get around 700rwhp on my turbonetics single turbo kit..
Old Jul 7, 2006 | 11:55 AM
  #52
Quamen's Avatar
Quamen
That would be amazing! Do you know when you are looking to switch your turbo. I may be interested in buying your T60 off of you.
Old Jul 7, 2006 | 12:17 PM
  #53
lex350's Avatar
lex350
Is it possible to just install a T66 inplace of a T60 and just run the stock boost for now. And then later after you build the engine you could increase the psi higher?
I'm asking because maybe I can just buy the T66 now and save some money but still run the stock psi which is 8-9 psi right?
Are there extra parts I would have to buy now or is it a straight swap of turbos.
Thanks
Old Jul 7, 2006 | 01:58 PM
  #54
MIAPLAYA's Avatar
MIAPLAYA
Thanks
Because 8 PSI on a T66 is not the same as 8 PSI on a 60-1. And you might surge the T66 trying to run lower then that.
Old Jul 7, 2006 | 02:25 PM
  #55
lex350's Avatar
lex350
Thats what I thought. Thanks
Old Jul 7, 2006 | 04:02 PM
  #56
BoOsTedz33TT's Avatar
BoOsTedz33TT
FYI:
Greddy out of box makes ~350-360 HP
Turbonetics out of box makes 365-380 WHP
that 350 on the greddy was probaly made on 4-5lbs
the 365 on the TN was probaly at 8-9psi.
Old Jul 7, 2006 | 04:16 PM
  #57
diwun67's Avatar
diwun67
Originally Posted by Gman2004
what is so sad about 360whp @ 5.5psi?
The $7k that was just dropped
Old Jul 7, 2006 | 05:52 PM
  #58
failsafe306's Avatar
failsafe306
But a retune along with upping the boost will quickly cheer you up
Old Jul 7, 2006 | 06:27 PM
  #59
BoOsTedz33TT
^1+...where you been...you gonna keep it or sell it??
Old Jul 7, 2006 | 06:42 PM
  #60
diwun67's Avatar
diwun67
Oh but of course Who really keeps their GReddy TT kit at the factory tune? lol
