turbonetics reflash to utec
Old Jul 3, 2006 | 09:40 PM
veilside350zTT's Avatar
veilside350zTT
Default turbonetics reflash to utec
I got the turbonetics reflash but im switching to UTEC now..Whose done this? Do I need to reflash my ECU back to stock.? Thanks!
Old Jul 3, 2006 | 09:49 PM
Gumpdriver's Avatar
Gumpdriver
I got it on my G. As long as you got the map switch you are OK. You will not need to reflash the ECU.
Old Jul 3, 2006 | 11:13 PM
JETPILOT's Avatar
JETPILOT
No MAP switch required. I have the TN reflash and the UTEC without a MAP switch.
Respect
JET
Old Jul 4, 2006 | 04:35 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
You do not need to flash it back to stock.
Old Jul 4, 2006 | 07:27 AM
Gumpdriver's Avatar
Gumpdriver
Respect
JET
Hey Jet, but don't you need that in case you want diffrent maps say one for cruising and one for the strip. Meaning differant octanes.
Old Jul 5, 2006 | 05:55 AM
down_shift's Avatar
down_shift
^^ Yea.. but you don't need it for a reflash to Utec..
The Just hit "0" on the Utec if you're not tuned yet and run the Flash, when you get tuned, it should be on the tuned map anyways..
Old Jul 5, 2006 | 07:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
No need for stock reflashing as mentioned. I have this combo, if your current TN tune is decent that will become your "0" map on UTEC-meaning your TN ECU parameters are controlling things. Any other maps you create after will have a designated number and the UTEC will override the TN flash WOT...
Old Jul 5, 2006 | 10:58 AM
Gumpdriver's Avatar
Gumpdriver
Mine is also 0 map.
Old Jul 5, 2006 | 11:09 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Thats how the UTEC works! Map 0 runs off the ECU.
Old Jul 6, 2006 | 11:54 AM
veilside350zTT
Do you think i will be able to run off the reflash during the break in period for my long block.? My car is 3.8L now and i got JWT Cams. Will it be able to run off the reflash like this? or should i put the Utec in now?
Old Jul 6, 2006 | 12:15 PM
Alberto's Avatar
Alberto
Cranky FI Owner
You'll be leaner WOT most likely but if you stay out of boost you should be fine.
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
mlemieux137
Tuning
15
Aug 2, 2004 05:15 PM
