Larger Blower Upgrade For Stillen On It's Way?
Old Jul 24, 2006 | 01:43 PM
BlackSpec02's Avatar
BlackSpec02
interesting idea....
everyone does keep saying that it will fit under the current stillen hoods... so maybe they did something like that to make it shorter, but i cant imagine getting it low enough to go under the stock hood... they would need it to be like 6 inches shorter... or stick it somewhere else, but i doubt they would do that.
Old Jul 24, 2006 | 01:54 PM
blown in nc's Avatar
blown in nc
Maybe it will be wider like the Kenny Bell? The current one is kinda narrow.
Old Jul 24, 2006 | 02:11 PM
Oleg's Avatar
Oleg
Originally Posted by ht4
There is no rule saying that a roots blower MUST be on top of the engine (though I will admit, it is the most convenient spot) but even is there was such a rule, I don't see why stillen couldn't redesign the lower plenum with shorter runners that would drop the blower down...
That's what the guys in Dreamworkes attempted plus the throttle body relocation. And their blower idea died b/c it ended up being way too expensive to produce and not able to compete with the TT kits in terms of value.
My guess at least.
Old Jul 25, 2006 | 12:42 AM
TTRANK's Avatar
TTRANK
I have a video from stillen where they said that they did design one that fit under the stock hood on the 350Z but did not have the IC and needed new injectors which was too expensive. The height of the current one allows for the 7th injector to properly mix the A/F before it goes in.
Vortech should come out with a smaller blower that spools up faster and fill in that gap in the market for people that only want ~375whp but less lag than the current kit.
Old Jul 25, 2006 | 06:20 AM
ht4's Avatar
ht4
Interesting... link?
What are you talking about?
Is that even possible with a CF SC? Don't forget that by its nature, a CF SC makes peak boost at redline. Not early in the rev range. The only way I can think of to do something like that would be with a wastegate-like device bleeding boost at high rpms... and that would be a serious waste of power. Not to mention inefficient and creating VERY hot charge air temps.
Old Jul 25, 2006 | 07:12 AM
TTRANK's Avatar
TTRANK
Yes it's very possible, you just gave one way to do it. The Stillen also makes peak boost at redline. It does not need to make peak boost early in the rev range to make power earlier, it just needs to spool up faster. A smaller blower would do exactly that.
Old Jul 25, 2006 | 01:09 PM
BlackSpec02
superchargers are belt driven... they are spooled by the belts... how do you expect one to "spool faster"? If you're talking about smaller pullies... then that can already be done...
Old Jul 26, 2006 | 02:27 PM
mok5's Avatar
mok5
Old Jul 26, 2006 | 03:36 PM
TTRANK's Avatar
TTRANK
If anyone cares I started this same thread on G35driver and there is some good info on there too.
I just sent Sam an email today asking a lot of questions about it and offering to be the G sedan mule if they decide to make it.
http://g35driver.com/forums/showthread.php?t=108397
Old Jul 26, 2006 | 05:15 PM
helldorado's Avatar
helldorado
Get a little petition going. I'll sign right on the first line of it.
Old Jul 26, 2006 | 06:10 PM
VN_350z's Avatar
VN_350z
Tell them that their hoods prevent many potential buyers from bying Stillen SC: THey need to come out with better hood...the thing is so ugly
Old Jul 27, 2006 | 01:06 AM
Triple8Sol's Avatar
Triple8Sol
I will sign that petition.
Just got my Stillen hood painted and installed on my G35c. Looks sick on DG
Old Jul 27, 2006 | 03:43 PM
MulhollandDrive's Avatar
MulhollandDrive
I like the hood on my ZR. I especially like it when some sedan starts pulling on me, looks over, sees the hood and backs off
Old Jul 27, 2006 | 09:53 PM
TTRANK's Avatar
TTRANK
I on the other hand like it when some coupe pulls up next to me, looks over, sees the hood and backs off.
Old Jul 27, 2006 | 10:41 PM
plumpzz's Avatar
plumpzz
they should do teh do luck style hood. Its crower style but w/ a curve instead of solid geometric shapes. The do luck hood is saucy.
Old Jul 27, 2006 | 10:51 PM
BlackSpec02
I wish they would do something like that... perhaps with a vent or two near the s/c to keep the temps down.
Old Jul 27, 2006 | 11:50 PM
FrickU's Avatar
FrickU
This will be interesting to see
Old Jul 28, 2006 | 03:37 AM
  #38
superchargedg's Avatar
superchargedg
Damn Noobs
come on tim if im ever down your way ill pull up next to you.
Old Jul 28, 2006 | 08:23 AM
  #39
TTRANK's Avatar
TTRANK
That would be great!
No one ever wants to race me around here. My car is fast but not that fast. I know if I could ever run into some of the TT/ST 350's around here they will race me. I may not like the result but I would still like to see how close I can stay.
Old Jul 29, 2006 | 01:14 AM
  #40
Fanman's Avatar
Fanman
Interesting. I saw the new D Sport today, and they have a Stage 3 Stillen putting out just shy of 330 whp @ 7psi. Said they have tested it at 8-9 psi (probably the stage 4). But Stillen said the reason why they won't go further is because at 380 whp you need to replace the rods, and other internal stuff. At least that was what was in the story.
