Supercharger HP #
Old Jul 18, 2006 | 09:35 PM
Cannysage's Avatar
Cannysage
Question Supercharger HP #
what are the highest numbers yall have seen in a supercharger (not ST/TT).
anybody ran one with built internals?
Old Jul 18, 2006 | 10:17 PM
sentry65's Avatar
sentry65
the burninator
highest is around 510whp i think
Old Jul 19, 2006 | 04:45 AM
booger's Avatar
booger
Who got over 500whp besides Derek from DSport Mag ?
Old Jul 19, 2006 | 07:33 AM
sentry65's Avatar
sentry65
the burninator
that's who I was talking about
Old Jul 19, 2006 | 09:19 AM
[]V[]addog's Avatar
[]V[]addog
what r the smallest numbers you will get from a average supercharger?
assuming stock Z, no other modifications
Old Jul 19, 2006 | 09:24 AM
Quamen's Avatar
Quamen
Someone got I think 575 to the wheel on an ATI but that was with a 50 shot of nitrous I believe.
Quamen's Avatar
Quamen
Im sure you could get as low as you wanted in reality for HP numbers by just underdriving it a bunch.
Old Jul 19, 2006 | 09:37 AM
sentry65's Avatar
sentry65
the burninator
stillen stage 1 will gain you like 35-40whp
Old Jul 19, 2006 | 05:37 PM
Cannysage's Avatar
Cannysage
that's less than my popcharger
Old Jul 19, 2006 | 10:15 PM
mraturbo's Avatar
mraturbo
Stillen
300 WHP...
With Upgrades 320 MAX...Owned 3 of them...
Procharger and Vortech...320-380 WHP
Up to 500 with Super Mods...Great Tuning...
M
Old Jul 20, 2006 | 09:21 AM
Quamen's Avatar
Quamen
The main limiting factor with superchargers that I see is that our engine is not big enough to turn a larger head unit with all of the factory accesories. I think that if you were running no power steering and no A/C you could run a slightly larger unit (procharger uses a C2, you could upgrade to the D-series that comes in mustang kits). Or if you had the engine stroked.
However, if you used serpentine belts to get rid of slippage you could possible run a larger unit yet.
Old Jul 20, 2006 | 10:35 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
420 on mine with stock internals. Vortech with the 3.12 pulley and exhaust mods.
J
Old Jul 20, 2006 | 01:12 PM
booger's Avatar
booger
When DSport Mag and Vortech figure out the cog pulley system for the car . You will see a 600whp car . The T-trim blower is plenty big enough and flows enough to support it . There really is no need for a bigger head unit .
My belt starts to slip at 13psi @ 5900rpm and if it didnt.....I think 18psi would be reached by 7000rpm . DSport is reving to 8000rpm's
Old Jul 20, 2006 | 01:20 PM
Quamen's Avatar
Quamen
I was talking ATI head unit. Many say that is starts to get towards over spinning at the 500hp level.
Old Jul 20, 2006 | 01:25 PM
TTRANK's Avatar
TTRANK
The Stillen will not get you over ~350whp.
Power under the curve and immediate boost are it's pros. Big numbers and power at high rpm are its lows.
Old Jul 20, 2006 | 01:30 PM
kzanard's Avatar
kzanard
There are a few of us with built motors. Some are really pushing good #'s. I am running conservative tune as I was experiencing the overheating /head lift issue a lot of people were experiencing and don't want to tear down for head gasket and stud upgrade yet. I am at 410hp/340tq. Could probably easily gain 40 or more whp with cams, plenum spacer, 2.87 pulley, etc.
Old Jul 20, 2006 | 01:41 PM
QuadCam's Avatar
QuadCam
you were lifting the heads? THAT'S THE 1ST i'VE HEARD OF a VQ35 having a head clamping problem.
Old Jul 20, 2006 | 01:49 PM
booger's Avatar
booger
OK..sorry
As far as head lift...I dont think it is head lift . But the cyl. moving around breaking the head gasket seal
Old Jul 20, 2006 | 03:59 PM
kzanard's Avatar
kzanard
There are several threads on the overheating and head lift "theories". I think my problems were a combination of air in the system and head gasket starting to fail like Booger said (I had the black gasket particles in my overflow). Booger knows better than I with regards to the cause. He just went through replacing his head gasket. I installed the head strengthening mod from Scott (overzealous1) and have had good success thus far.
Old Jul 20, 2006 | 04:03 PM
booger's Avatar
booger
Im just going by what my shop has explained to me . They have had alot of the same problems with open deck Honda's .
