Vortech installed, but one puzzling little thing.
Old Jul 28, 2006 | 05:22 PM
RA11325's Avatar
RA11325
Default Vortech installed, but one puzzling little thing.
Ok first off Vortech is AWESOME. This ****er pulls like there is no tomorrow. Im in love.
Ok, now for the issue...my airbag light is flashing. I had to seats out to do the electronics and i put them both in correctly and connected the 1 plug on each side. Did i miss something? could it be somthing else?
Old Jul 28, 2006 | 05:27 PM
GMZ's Avatar
GMZ
Why did you take seats out? What EMS are you using? Did you maybe cut or nick a wire somewhere? Did you use a harness or splice into the ECU? Did you try taking off the - battery lead? Did you have it taken off while you were putting it back? Id be careful, would be bad if one of those suckers went off. Need details! I got mine in a week ago and am loving it also
plumpzz's Avatar
plumpzz
Reset ECU? I know you're not allowed to take the seats out. If anything and it wont go away, theres a harness that mynismo.com sells that cuts the airbag light, but i think the airbag will no longer work.
(ehem, time for lightweight aftermarket steering wheel :-D )
Old Jul 28, 2006 | 05:37 PM
RA11325's Avatar
RA11325
I took the seats out so that i had more room to work with the wiring, i spliced everything into the existing harness. The car runs absolutely flawlessly other than that light being on. Could it have anything to do the my gauges? I tied them into a switched 12v source under the drivers side dash....I tried resetting the ECU but it is still flashing.
Old Jul 29, 2006 | 02:56 AM
se-r / gti-r's Avatar
se-r / gti-r
way to go.......u screwed it up again!!!....................dumbass!
good to hear you got that thing going
PS: I got something new
Old Jul 29, 2006 | 10:24 PM
RA11325's Avatar
RA11325
nice.....so anyone have any idea?
Old Jul 29, 2006 | 10:27 PM
FrickU's Avatar
FrickU
If you noone else can figure it out then I would just say, on your spare time take out the seat and make sure EVERY connection is right...It is probably just 1 wire lol. We all get that kind of luck sometimes. Good luck with the problem
Old Jul 29, 2006 | 10:39 PM
RA11325's Avatar
RA11325
Yea probably what ill have to do tomorrow after work. Ill disconnect the battery and remove and replug in the seats again. Thanks guys.
Old Jul 29, 2006 | 10:42 PM
FrickU's Avatar
FrickU
No problem...Crap happens, but i'm really glad to hear that you are having fun with the vortech and that it is working great
Old Jul 29, 2006 | 10:54 PM
G352NV's Avatar
G352NV
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away.
Old Jul 29, 2006 | 10:56 PM
FrickU's Avatar
FrickU
You learn something new everyday
Old Jul 29, 2006 | 10:58 PM
RA11325's Avatar
RA11325
IT WORKED!
Thanks G352NV!
Old Jul 30, 2006 | 02:33 PM
CFZ's Avatar
CFZ
Thanks, worked for me too. My airbag light has been flashing for months now due to something setting it off while changing seats even with jumpers in place?
350Z_Al
Oct 29, 2020 07:44 PM
