Ahhh P300 code is back again.
Old Sep 5, 2006 | 03:24 AM
  #41
k3silk's Avatar
k3silk
lets hope that this is the problem. we will see. Change out you cats and let everyone know. also did anyone else have stock cats when having this problem?
Old Sep 5, 2006 | 05:34 AM
  #42
sakred's Avatar
sakred
i just recently got this problem. a few days ago i had my cracked header (passanger side) replaced from my local shop. also my car before this was running great and made lots of power for NA atleast all the way up. i had some no name brand test pipes on. (non resonated). well while the header replacement i wanted to get some resonated test pipes installed. the shop installed and them and since then i felt this drop in power as i go higher in the RPM range. making the car feel very sluggish uptop. where before my car would start to really move up top now its hesitating in gear. i hoked up the scan tool to the car and get a multiple engine missfire code, this seems very odd that my car would do this now seeing as how i had the non resonated test pipes on my car for almost a year now. i had a check engine light but never a missfire code. any help would be appreciated.
Hammad
Old Sep 5, 2006 | 06:46 AM
  #43
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by TIMMAHH
Oh yeah! I forgot that I put on kinetix cats about the same time I started having this problem. I need to put my stock cats back on and see if that fixes it.
I have those cats too but when I was NA i didnt throw a p0300.
Old Sep 5, 2006 | 11:14 PM
  #44
TTRANK's Avatar
TTRANK
I know the Stillen SC does not like high flow cats or test pipes. I am going to take them off this week.
Old Nov 1, 2006 | 09:28 PM
  #45
TTRANK's Avatar
TTRANK
Just to close this out. I put the stock cats back on, gained about 0.5lbs of boost and have not seen the code since.
Old Nov 1, 2006 | 09:32 PM
  #46
sentry65's Avatar
sentry65
the burninator
did you gain boost and lose power?
Old Nov 1, 2006 | 09:34 PM
  #47
TTRANK's Avatar
TTRANK
I never got a dyno. I doubt there was much change. The plan was to do headers and h/f cats, unichip, injectors, and a smaller pulley to help get the lost boost back.
By the time I add all that up I might as well sell this kit and spend a little more for a set of twins.
Old Nov 1, 2006 | 10:08 PM
  #48
brooke's Avatar
brooke
I have recently had the same problems with my aps tt setup. Rough idle, die whenever I come to a stop but when I plug the stock ecu back in and run that it seems to run fine. I have checked my injectors, replaced plugs, checked for vaccum leaks, etc but still have no clue whats going on? I just sold my unichip thinking there was something wrong with it but I had grd check it out and they said it was fine. I now have the utec and even with the aps tt map from turbo xs it is doing the same thing. I'm starting to think it has something to do with the fuel...
brooke
Old Dec 13, 2006 | 05:15 AM
  #49
Machupo's Avatar
Machupo
Originally Posted by sentry65
the P0300 is my friend. My dash is lonely without him
i've got 8.6CR pistons, so really, P0300 is my friend
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
