G35 T-NETICS intercooler fan ???'s
Old Aug 1, 2006 | 05:55 PM
g356gear's Avatar
g356gear
Default G35 T-NETICS intercooler fan ???'s
Do they run all the time when the car is idling?? I helped a buddy install his kit on the weekend and he can't get the intercooler fans to run when the car is at idle....hot or cold. Any ideas?? Bad module??
Old Aug 1, 2006 | 06:15 PM
G3.5T's Avatar
G3.5T
They should run all the time at low speed, then when you go into boost they should kick onto high speed.
Old Aug 1, 2006 | 06:16 PM
G3.5T's Avatar
G3.5T
I would check that the hoses to the module are not pinched or disconnected.
Old Aug 1, 2006 | 08:16 PM
MIAPLAYA's Avatar
MIAPLAYA
Yup the fans should come on as soon as the motor is started and run at 6 volts off boost. The relay kicks up the fan power to 12 volts when you hit 1 PSI of boost. I'd say check your connections.
JjL
East Canada
Jun 12, 2019 03:04 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
mjgfish
Sep 22, 2015 05:55 AM
