Pistons and con. rods
Old Aug 13, 2006 | 04:23 AM
silver nismo's Avatar
silver nismo
Default Pistons and con. rods
need help knowing a good brand to install on my car with the greddy TT kit.
the one that they are getting are good but i just wanted to make sure if the price is cause its costing 2666 $.
Old Aug 13, 2006 | 05:27 AM
Immortal's Avatar
Immortal
This is in the wrong section, try FI.
State what internals you're getting and how far you want to push the block.
Old Aug 13, 2006 | 05:47 AM
silver nismo
Default oooops
sorry i just cant get it right. thanx for the help
Old Aug 13, 2006 | 07:27 AM
chimmike's Avatar
chimmike
carillo rods, or cunninghams, and arias extreme duty pistons.....for that price it still seems kinda steep unless that includes install.
Old Aug 13, 2006 | 08:44 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I'd suggest the following for a very solid setup....sky is the limit....powerwise.
Pauter rods: $1150
Arias Extreme Duty Pistons: $1050
ARP L19 head studs: $490
ARP standard main studs: $200
Cosworth single fit Tri-Metal rod Beaings: $100
Cosworth single fit Tri-Metal main bearings: $100
All in stock.
Old Aug 13, 2006 | 08:47 AM
mraturbo's Avatar
mraturbo
That Should be a strong set-up for sure!
M
Old Aug 13, 2006 | 10:31 AM
KTaylor's Avatar
KTaylor
+1 on carrillo rods and arias ED pistons
Old Aug 13, 2006 | 07:34 PM
QuadCam's Avatar
QuadCam
what are your hp goals?
if you aren't trying to "set the world on fire," you can go with Wiseco Pistons and Eagle rods. if you search hard enough, you can get both for about $900 or less.
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
B Esquire
Sep 24, 2015 07:52 AM
