Project Built TT G35 by Speed Force Racing
Old Aug 16, 2006 | 08:47 AM
  #41
G352NV's Avatar
G352NV
Originally Posted by g35_anonymous
appriciate the input G352NV...
I had no dreams of FI when I bought the car and made the mistake of getting the oem NAV, I kicked my self for that... Your dash is def. nice and well thought out, but i'm trying to keep it semi-close to oem looking. I also wanted to keep the clock/AC readouts in tact, so I didn't want to mount that high up on the dash...
My original idea was to gut the nav screen and place the gauges inside the nav screen housing, keeping the motorized stow capabilities. This was not possible because of depth limitations...
Your car is sick btw...
The only thing modded on that AC console is that there is gauges on top of it. Everything else works like stock. Its just hard to see the panel in the pic, but its there. No biggie I was just trying to throw out a few ideas. I hate to see someone loose the screen. Good luck with the build. Looks like your doing everything right so far!!!
Old Aug 16, 2006 | 09:12 AM
  #42
BamBam's Avatar
BamBam
Very nice setup man... You definitely put a lot of time and effort into the appropriate parts necessary for reliability, performance and looks.
I am sure you can't wait until it is done and on the road.. I know waiting for mine is driving me nutz, but we are almost there…
Old Aug 16, 2006 | 05:44 PM
  #43
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
The tube on the back of the plenum is a balance tube to equalize the airflow of each plenum.It is there for functionality first and looks second.We ended up using a mandrel bent tube to give it a more symetrical look since the plenums are offset from each other.
No one even said anything about the headers....sob..... sob......The gauge panel was something I made real quick to give Matt an idea of what we were thinking.We were going to do something similiar to the one on the G picture in this thread(which is way cool except we were going to do it where this new gauge panel resides now).Give it a little bit of the Z flavor.All out of aluminum too.No glass here.But Matt didnt want to go that route so we went with this instead.Matt also got the dual 3" Carbon Ti exhaust and all sorts of other cool stuff like a Koyo radiator that bolts right into a G(we made a jig if anyone wants a direct bolt-on Koyo).We also adapted some Spal fans and we even have an aluminum fan shroud for the twin fans.Matt did not want the shroud though but I am trying to convince him to get it.
Tim
Old Aug 16, 2006 | 06:48 PM
  #44
Weqster's Avatar
Weqster
Headers look good. EL and decent turbo placement. So good I thought they were from another turbo kit? JWT? Only thing i can knock would be wastegate placment (angle off the collector) but i suppose that consequential of space restrictions.
Old Aug 16, 2006 | 10:12 PM
  #45
g35_anonymous's Avatar
g35_anonymous
Tim... Beautiful Headers...
now that i've buttered you up a little... ok let's do the fan shroud and call it even.
Old Aug 16, 2006 | 10:22 PM
  #46
NoLimit's Avatar
NoLimit
^^ That kit is made completely by Tim.... No other Z/G TT kit uses the SS headers! I love those things! , ... i think they may be part of my "special" kit once I get back to the land of the living!!
And how is the wastegate placement any worse than Any TT kit out right now??
Old Aug 17, 2006 | 01:53 PM
  #47
TurboTim's Avatar
TurboTim
The wastegate placement is almost optimal. Ideally the wastegate should be installed right near the turbo inlet so that both the wastegate and turbo inlet have the exhaust entering at the same time.This would be optimal.However,there is not enough room.
Tim
Old Aug 17, 2006 | 05:21 PM
  #48
bverschage's Avatar
bverschage
Subscribing...
Old Aug 18, 2006 | 01:02 AM
  #49
joust75's Avatar
joust75
Teh separate intake plenums give me wood.
Subscrizibin for finished product. Nice work!
EnjukuRacing
Sep 30, 2015 06:55 AM
