UTEC Tuner wire color question??? blue and white wires??
Old Aug 19, 2006 | 09:18 AM
QuadCam's Avatar
QuadCam
Default UTEC Tuner wire color question??? blue and white wires??
I am posting in this section because not many people view the "tuning" section. at any rate, My TurboXS Tuner wideband has a blue and a white wire coming off the main harness. TurboXS doesn't send any instructions referring to these wires, and the online instructions talk about a red and black wire. I assume that the blue and white wires are the "switched +" and the "ground."
Does anyone know which is which? I already spoke with someone on this foum, and he told me that his wires weren't blue and white.
thanks,
Andrew
Old Aug 19, 2006 | 10:03 AM
techcontrol's Avatar
techcontrol
I don't have the tuner, but the only blue and white wires I have come from the map switch. What they go to I have no clue. I've seen no mention of them anywhere.
Old Aug 19, 2006 | 10:16 AM
Kenk2's Avatar
Kenk2
Professional
Andrew,
White is ground and blue is 'switched +' I tapped into the EXTRA 12v power NEXT to the glove box. It is KEY ON, so there is only power to it when obviously the key is turned to 'ON'. The wire you tap into I believe is RED with a BLACK stripe.. worked well for me and is the closest/ easiest power I could find.. I bought a pack of wire tappers?? or whatever you call them and when I put the red wire(in your case blue wire) in the wire tap, I had to double it up.. The wire is too small for it to go in there and make a good connection.. Make sure you have some pliers handy and electrical tape.. I took some pics but have yet to post them as I have been busy as hell.. I am at work now so when I get home I will post them up..
Ken
Originally Posted by QuadCam
I am posting in this section because not many people view the "tuning" section. at any rate, My TurboXS Tuner wideband has a blue and a white wire coming off the main harness. TurboXS doesn't send any instructions, and the online instructions talk about a red and black wire. I assume that the blue and white wires are the "switched +" and the "ground."
thanks,
Andrew
Old Aug 19, 2006 | 11:25 AM
QuadCam's Avatar
QuadCam
how sure are you? I know I have a 50/50 chance...its just sucks!
Old Aug 19, 2006 | 02:03 PM
Kenk2's Avatar
Kenk2
Professional
LOL!! Well with mine, the white was ground.. I had a red and white cable..
Old Aug 19, 2006 | 02:11 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
blue goes to the left rear window control and white goes to the HI radiator fan!!
glad you got it all working man!!
Old Aug 19, 2006 | 03:09 PM
QuadCam's Avatar
QuadCam
That worked!!
BTW, I still can't connect to the Tuner through my laptop. The tuner powers up, counts down, and then displays "gas." I just can't get it to connect!
Old Aug 19, 2006 | 05:20 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
they are famous for the "extra wires that nobody wil ever use"
for the tunerpro, you have a "+" and a ground, there is another set of wires coming off the harness that are not used for anything...
Old Aug 20, 2006 | 08:43 AM
Kenk2's Avatar
Kenk2
Professional
It might be a little late now but I said I was going to post some pics.. Maybe they will help someone else out in the future..
Here goes..
First pic is just the UTEC with glove box tore apart..
This pic is where I tapped into the extra 12v power supply next to the glove box in the G35..
Last pic is of everything after I finally got power to the Tuner..
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
cashmoney03
Sep 27, 2015 05:24 PM
smithmt3
Sep 11, 2015 08:25 PM
