Leak Help!!
Old Aug 19, 2006 | 03:23 PM
ShAdY908's Avatar
ShAdY908
Default Leak Help!!
Just go tmy APS ST installed. I was driving and heard a loud whoosh as if a hose came off and now my car wont boost past 2-4 psi and the blowoff valve doesnt do the usual shutter it is just a low toned whoosh. Not to mention the large hose going into the drivers side of the intercooler has a lot of oil dripping out of it. What is going wrong here?
Old Aug 19, 2006 | 03:28 PM
chimmike's Avatar
chimmike
well, for one thing, that's blowby (the oil). Another thing....check and make sure all the piping is still connected at the couplers. If not, put 'em back in the couplers and tighten down!
Old Aug 19, 2006 | 03:33 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Check your couplers and lines
Old Aug 19, 2006 | 03:34 PM
ShAdY908's Avatar
ShAdY908
what couplers in specific you mean the clamps by the intercooler hose and what not? I am also getting a lots of smoke out of the exhaust when I push the pedal
Old Aug 19, 2006 | 03:35 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yes, all of them. Intercooler, turbo, MAF, TB.
Old Aug 19, 2006 | 03:37 PM
chimmike's Avatar
chimmike
hmm. either you simply popped off a coupler, or your seals in the turbo blew.
Old Aug 19, 2006 | 04:09 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
you will suck in oil on the valve cover lines too that are connected to the intake side of the turbo, you just blew off a coupling somewhere, and its not between the maf and the throttle body, check all the hose clamps/t bolts really good and see if you find any couplings that are blown off..
Old Aug 19, 2006 | 05:23 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i have blown off the couplers 2 times in the past two weeks, each time, a different coupler...i really need some better quality clamps..the most common area is where the turbo links up to the intercooler...2nd option is the hard to reach pipeleading to the pipe that goes to the intercooler (by the radiator)...
Old Aug 19, 2006 | 05:37 PM
ShAdY908's Avatar
ShAdY908
i retightened the clamp in the front side of the radiator.. im still blowing a massive amount of smoke out of the exhaust its crazy. idk what is wrong
Old Aug 19, 2006 | 05:43 PM
QuadCam's Avatar
QuadCam
if you are suxking in unmetered air, your car will puke and blow smoke like crazy. Check to see if an air is getting sucked in after the MAF. check for leaks around the intake manifold, too.
If that's not it, check the valve cover vents. pull the tubing off of them an see if smoke is coming out of them. If so, you may have broken the ring lands on your pistons. I hope that's not it!!!
Old Aug 19, 2006 | 05:45 PM
QuadCam's Avatar
QuadCam
I forgot one more thing. you could have had the seals int he turbo go bad. If so, you could be getting oil passing into the compressor side of the turbo and you are slinging oil through the intake piping tract. from what you had mentioned earlier, this may be a real posibility.
Old Aug 19, 2006 | 09:23 PM
ShAdY908's Avatar
ShAdY908
intake mani & maf looks to be fine... dont know what you mean about valve cover vents.... lastly the turbo sounded like it was spooling fine
Old Aug 19, 2006 | 09:37 PM
failsafe306's Avatar
failsafe306
Since you have the APS ST, you probably need the replacement check valve. You shouldn't be dripping oil anywhere, blowby or not.
As far as the low boost thing, just be sure to check all of your hoses and couplers, as the other guys have stated before.
Old Aug 20, 2006 | 01:24 PM
ShAdY908's Avatar
ShAdY908
Well we just flatbedded it to Infiniti to wait there for tomorrow, the car is dripping oil out of the exhaust it was flowing out, were pretty much going to sue them or atleast get compensation
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
