PE TT Water cooled Turbos
Old Aug 26, 2006 | 07:54 AM
gringott's Avatar
gringott
Originally Posted by GurgenPB
Let me comment on that. What you are saying makes logical sense. However, my oil temps did drop 3-6 deg C after installing the water cooling, and by water temps rose by about 2-4 deg C or so, like i posted before. This supports the idea that there is some, albeit minor, heat removal during engine's operation. Also, there are other factors involved tat would contribute to oil temps. It is a fact that upgrading the radiator lowers oil temps as well, it did so in my case pretty considerably. It also states so in the corky bell book. So the APS that saw higher oil temps could have been easily a function of poor water cooling.
As far as problems with the turbos, I had to replace my d-side turbo because of a bent shaft, which is very much a symptom of hot bearings, from what my research has revealed. The car was absolutely asymptomatic, more over, just removing the turbo and inspect the impeller and the bearing play did not reveal a problem, only when you try to spin the impeller by hand, then you'd see an obvious and unmistakable hesitation at every 360 deg of rotation. Who knows, maybe this hadn't much to do with the water cooling, but maybe it did.
I get what you are saying, I did not know about your turbo. I know that you are very good about measuring temps. I can see that increasing cooling capacity or efficiency will lower oil temps on a turbo system with water cooling or not. After all, the heat in a engine will transfer from one to the other if for no other reason than they are sharing the same block of metal.
I also think that IHI designed a water cooling jacket for a reason, like you do. I think that the water cooling can only help extend the life of the turbo, and would certainly do no harm.
Gurgen, I like to think of you as the "mad scientist" of the PE kit.
Old Aug 26, 2006 | 11:21 AM
KTaylor's Avatar
KTaylor
haha he is
Old Aug 26, 2006 | 11:37 AM
captj3's Avatar
captj3
Gringott you took my post wrong I'm not knocking the kit. But for the price I think they should have included the lines. Like gurgen said IMO they IHI designed the turbos for water cooling and it should have been included.
Old Aug 26, 2006 | 02:21 PM
gringott's Avatar
gringott
Looking from my perspective, I must agree.
Old Aug 27, 2006 | 08:20 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Hahah.... I am mad to put up with it that's for sure. thanks....
Gringo, you are right....water cooling allows to essentailly prevent the the problem of oil coking, which is a huge problem. With the watercooled turbos, you technically do not need a turbo timer at all, as the temperature is transferred to the water very very efficiently and removed, without the temps going over the coking temp threshold (or good measure, however, I do still run the car for 60 seconds after shutting off, instead of at least 2.5-3 minutes (since i laready have the timer installed)). This is what allows the bb turbos to last as long as they do. I do not know of anyone with BB turbos that were probably water cooled that had to be overhauled, with the exception of one that i know of that was bad from the get go, and it was promptly replaced by the supplier. However, there are a few Greddy kit turbos (the mitsu's) that had tobe rebuild when they were taken off and inspected between engine rebuilds, many of these people that encountered this good friends of mine.
as far the kit: With the shortcomings of the kit in mind, it still gives you something that no toehr kit gives, the pe1420 turbos. These turbos have a very broad efficiency characteristic, as opposed to high PR efficiency. I.e. the compressor maps are wider rather than taller, which provides a flatter torque response (at least in theory).
Old Aug 28, 2006 | 09:18 PM
AmyCroft's Avatar
AmyCroft
Smile Clarification
Let me comment on that. What you are saying makes logical sense. However, my oil temps did drop 3-6 deg C after installing the watercooling, and by water temps rose by about 2-4 deg C or so, like i posted before. This supports the idea that there is some, albeit minor, heat removal during engine's operation. Also, there are other factors involved tat would contribute to oil temps. It is a fact taht upgrading the radiator lowers oil temps as well, it did so in my case pretty considerably. It also states so in the corky bell book. So the APS that saw higher oil temps could have been easily a function of poor water cooling.
As far as problems with the turbos, I had to replace my d-side turbo because of a bent shaft, which is very much a symptom of hot bearings, from what my research has revealed. The car was absolutely asymtomatic, more over, just removing the turbo and inspect the impeller and the bearing play did not reveal a problem, only when you try to spin the impeller by hand, then you'd see an obvious and unmistakeable hesitation at evry 360 deg of rotation. Who knows, maybe this hadn'tmuch to do with the water cooling, but maybe it did.
Gurgen, In the above discription of the "Bent Turbo Shaft" I don't think you made it clear to the "Readers" the sequence of event's. Not all members have followed the "Story Line". One might assume that the failure was with water cooling. Please clarify the steps and mods you have added to make the VQTT more robust.
Thanks
Cheers Amy -
Old Aug 28, 2006 | 09:24 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Thanks
Cheers Amy -
John,
The bent shaft was indeed very likely due to water cooling...although it could have been due to inadequate turbo-timer cool down (didn't own one in the beginning) from when i originally installed the kit. I do not think it has anything to do with teh engine swaps.
Old Aug 28, 2006 | 10:06 PM
AmyCroft's Avatar
AmyCroft
Smile I'm suprised...
John,
Gee Gurgen, I'm suprised that you think the water cooling was not effective. Even more suprised you credit the Turbo's failure on water cooling.
The turbo timer method of running the engine a few minutes at idle to prevent "Coking" is suposedly a decent way to prevent the "Coking".
In one of my 1981 ZXT's I had a very interesting method. I would shut the car off, and a five minute timer provided oil via an electric pump to cool the turbo down. That T3 has lasted 110,000 miles to date. ( Yes it's loose ) - Still running but with a manual cooldown. I'd add a turbo timer on the next (fourth) T3.
Car has 200,000 total.. That's the Silver one. The White ZXT car only has 95,000 total, but on the original turbo. I wish we had water cooling on those.
Cheers Amy -
Old Feb 18, 2007 | 02:01 PM
CESAROTORRES's Avatar
CESAROTORRES
Default Good information THX!
Thank you everyone for contributing.
Cesar
Orlando florida
Old Oct 30, 2008 | 09:14 AM
Blck350z's Avatar
Blck350z
Is there anyone out there running the PE TT kit w/out water cooling them???? Also where do the lines hook into the coolant system???
Old Nov 1, 2008 | 02:54 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Did you ever get the water lines hooked???
Old Nov 2, 2008 | 02:20 PM
Blck350z's Avatar
Blck350z
I do not have any water lines or the hardware to make any yet... "banjo bolts etc....
Old Nov 3, 2008 | 05:59 AM
GC71's Avatar
GC71
I do not have the waterlines hooked up as well.
Although I am not high boosting my car, I do not doubt that installing them would help in increasing the longevity of the turbos.
Juz that I'm kinda lazy about ordering the parts from seperate vendors and piecing them altogether..something wrong is bound to happen when you do it this way worse when you are mail ordering the parts..
In there any complete kit from PE we can buy or can we use the APS water lines as a kit complete with all the bolts, joints connectors etc?
Old Nov 3, 2008 | 09:33 AM
350z-900whp's Avatar
350z-900whp
when i had my PE-tt gtm installed waterlines for my kit guys u can check with them for parts number ..etc if u would like to get your waterlines.
link
https://my350z.com/forum/shop-builds...1-500rwhp.html
Old Nov 7, 2008 | 02:48 PM
priscilla ls1's Avatar
priscilla ls1
Lets see how this goes. I would like to see a do-it-yourself kind of thing.
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
