Can you lower PSI boost on a Turbonetics Kit?
Old Aug 23, 2006 | 05:35 AM
NismoBlck350z's Avatar
NismoBlck350z
so Putting a five psi spring in and then a boost controller, you would be able to raise the boost above the 5 back to say 8psi?
Old Aug 23, 2006 | 05:53 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes. The spring will provide a base level of boost control. A boost controller can then allow you to run higher boost to a level of your choice. Although general rule is that you can safely run 2X the boost of the spring, so on a 5lb spring if you wanted to run 15psi--->while it may work, you'd be better off upgarding to say an 8-10lb spring.
Old Aug 23, 2006 | 08:49 AM
2fast4thelaw's Avatar
2fast4thelaw
This is exactly what I needed to know. Thank you guys for your expertise.
Old Aug 23, 2006 | 09:20 AM
solidsnake's Avatar
solidsnake
Originally Posted by taurran
What's wrong with that? It means running 93 is just an added measure against detonation. I wouldn't expect much (if any) power gain from running higher octane fuel, it's mainly a safety measure.
freaked me out there for a second.
apex locator
Jul 23, 2021 02:27 AM
