Drain Plug on APS Oil Pan TQ Specs?? HELP!
Old Aug 26, 2006 | 12:26 PM
maximumsportZ's Avatar
maximumsportZ
Default Drain Plug on APS Oil Pan TQ Specs?? HELP!
Just doing my oil change and forgot the tq specs completely on the drain plug on my APS oil pan.. Help anyone??
Old Aug 26, 2006 | 12:58 PM
failsafe306's Avatar
failsafe306
I do mine till it's finger tight, then about 1/2 to 3/4 of a turn. Basically just enough to feel the copper washer start to crush. You replaced the washer right?
Old Aug 26, 2006 | 01:10 PM
maximumsportZ
Which crush washer are u using? I didn't think the OEM would work because the APS drain plug looks bigger.
Old Aug 26, 2006 | 02:59 PM
failsafe306
Right, you'll need to take the plug up to the auto parts store and find the right size, and buy like 10 of them while you're there, lol.
Old Aug 26, 2006 | 10:23 PM
maximumsportZ
OH man!
Well, I went and started to tq down the plug when it wont tighten!!! it just keeps spinning and I swear I hardly used any force to strip it. So I try to loosen it and it just spins there!!!!!! I left it and filled it back with oil started for a little and let it idle no leaks. So I guess I'm screwed until the next 3K comes up and I have to remove the plug to change the oil.
How could I have caused damage when I hardly tq'd it down???
Old Aug 26, 2006 | 11:55 PM
Nismo350ZRT's Avatar
Nismo350ZRT
You actually torque the oil pan plug???
Old Aug 27, 2006 | 12:01 AM
maximumsportZ
Not really, service manual calls for 25ft-lbs on the stock pan.
Old Aug 27, 2006 | 01:10 AM
baptist's Avatar
baptist
I always just did it up hand tight, then maybe half a turn. Never heard of anyone actually torquing down drain plugs, just use your discression to make sure it isnt too tight.
Old Aug 27, 2006 | 05:49 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I always turn mine just past hand tight, and I've yet to replace the copper washer. No leaks to date.
You very well could have stripped the threads out of the pan. Though you'd have to torque it pretty good to do that.
If that's the case you have a couple options when your next oil change comes around. If you can get the drain bolt out then you could rethread the hole a little larger and use a different bolt. If that doesn't work, you might have to replace the APS oil pan.
Old Aug 27, 2006 | 06:49 AM
mojo powered's Avatar
mojo powered
although I don't highly recommend this, a cheap last solution is a rubber oil pan drain plug you can get from Autozone.
it fits snug and expands as you tighten the screw in the middle. I used this on my beater and it worked like a charm. But on the Z, I'd probably first try to rethread and use a larger drain bolt.
Old Aug 27, 2006 | 07:18 AM
maximumsportZ
Thanks guys, we'll see what happens next time around.
Old Aug 27, 2006 | 07:39 AM
failsafe306
You may have cross-threaded it or something. Plus, you probably shouldn't use the factory torque spec; the OEM pan is steel and the APS is aluminum.
Old Aug 27, 2006 | 04:27 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I firm tug with a wrench is all I do. Those plugs have never leaked......wish Nissan made a rear main seal like that.
Old Oct 10, 2007 | 11:44 AM
Abishop's Avatar
Abishop
sorry for bringing up an old thread, i would just like to know what happened after you changed your oil the next time? I have the same problem.
Old Oct 10, 2007 | 06:30 PM
maximumsportZ
Wow, memories... yea man you need to be very gentle on this pan. I ended up removing the plug and getting it re-tapped with pipe threads, no problems since.
Don't feel bad, me and you are the only ones to come out and mention our mistake. I know about 10 other owners who also stripped the pan.
Good luck.
Old Oct 11, 2007 | 07:18 PM
SSP-350z's Avatar
SSP-350z
Yeah I did the same thing with mine.... What plug did u end up using after re-tapping it ?
Old Oct 11, 2007 | 08:06 PM
Abishop's Avatar
Abishop
well i fixed mine today, i got a self tapping 1/2" double oversized plug from NAPA, cut its own threads, cleaned out the shavings, nice thick bead of red high temp rtv silicone gasket maker on the pan. Its setting up as we speak, tomorrow after noon hopefully it won't leak when i fill it with oil.
Old Oct 12, 2007 | 06:30 AM
maximumsportZ
Good job, I used one of those hex plugs to screw into the pan. I usually put some mild thread selant on the plug after every oil change for reassurance.
Old Nov 27, 2009 | 06:22 PM
G35cTT's Avatar
G35cTT
If the plug keeps spinning did you have to pull the pan to get the bolt out? Mine just stripped, it keeps spinning
