New to the TurboCharged World.. Need help with gauges
Old Aug 26, 2006 | 09:17 PM
JakexTrainer's Avatar
JakexTrainer
Default New to the TurboCharged World.. Need help with gauges
I just got a Turbo car with a bunch of gauges.. could any 1 tell me what they do..
Pro Comp : Air Fuel Ratio Meter
Pro Comp : Boost Guage
Blitz : Full Auto Turbo Timer
GReddy : PROfec 8-spec II
Old Aug 26, 2006 | 09:21 PM
ABL 2 FLY's Avatar
ABL 2 FLY
I think you may be a little in over your head
Old Aug 26, 2006 | 09:25 PM
Nealoc187's Avatar
Nealoc187
The air fuel gauge really does nothing - it's just for show unless it's a wideband O2 gauge (which your description indicates it is not).
boost gauge tells what amount of boost or vacuum your car is seeing at any given moment.
blitz FATT is a turbo timer, keeps the car running after you shut off the ignition for a short time in order to prevent oil from overheating and coking in the bearing cartridge of the turbo. it also has a built in boost gauge which may or may not be hooked up (also a built in peak-hold feature which shows the highest boost you've achieved since resetting it).
Profec B Spec-II is a boost controller, you can use it to turn up and possibly down how much boost your turbo makes (depending upon how low it is currently set). I'd highly advise NOT messing with this until you've become much more familiar with the car (assuming the car is tuned already and is currently running a safe boost level)...
You've got some learning to do it sounds like, and I'd suggest maybe picking up the book "Maximum Boost" by Corky Bell. You might be in for a very expensive, very harrowing time with this new car if you don't do some serious learning with a quickness.
Old Aug 26, 2006 | 09:34 PM
JakexTrainer
Thanks alot ill look into that book
Old Aug 27, 2006 | 06:52 AM
tropicalypso's Avatar
tropicalypso
It would probaly be a good idea to find a solid tuner that you can trust so that you can take your car in periodically to make sure its running right.
Old Nov 15, 2006 | 10:33 PM
DMK's Avatar
DMK
I'm about to get some gauges as well, just A/F Wideband and Boost. I recently saw an Evo with gauges near the A pillar, but they were not in a pod. They were stuck near the A pillar vertically by suction cups. To me, this looked a lot cleaner than a pillar pod. Does anyone know who makes these gauges?
sales@czp
Sep 23, 2019 03:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
