Crazy SC idea?
Old Aug 27, 2006 | 07:28 PM
Alang's Avatar
Alang
Default Crazy SC idea?
OK, I've had a few galsses of wine, and my brain is obsessed with my upcoming Vortech install and I came up with a very weird idea.
One big advantage turbos have over SCs is that they reach full boost much lower in the RPM range. This of course is because exhaust pushes the turbo and the wastegate controls the boost level as opposed to the engine RPM which is controlling the SC boost. With a centrifugal SC like the Vortech, wouldn't it be possible to install a compressor that makes say 14lbs of boost at redline, and a boost controlled bypass valve up stream of the MAF that limits the boost to say 8psi. The larger compressor would reach the 8psi level much lower in the RPM band, and it would act more like a turbo as far as power delivery is concerned. If the bypass valve is before the MAF, then there should be no worries of metering air that is released.
This idea seems too simple for someone like me to have thought of it first, so there must be a flaw somewhere. What is it my little wine stained mind is missing that this won't work?
Old Aug 27, 2006 | 07:36 PM
tig488's Avatar
tig488
its been done, try searching for it. i cant remember the guys name, he had a G sedan, something like G35spot.
Old Aug 28, 2006 | 04:37 AM
booger's Avatar
booger
Yes that is the guy . I also tried it . It just doesnt work well enough to hassle with IPO
Old Aug 28, 2006 | 07:27 AM
blown in nc's Avatar
blown in nc
ECS does this with C5s for Vortec, Procharger, and Novi by using a restrictor plate. The boost comes on faster and "all at once" compared to one that builds boost as the rpms climb. It still doesn't fully compensate for the high torque results with a turbo.
Old Aug 28, 2006 | 09:17 AM
Quamen's Avatar
Quamen
Another thing to consider is that even though you will be reaching desired manifold pressure earlier the SC will continue to reach higher compressor pressures which means higher temperatures. So in reality, without higher boost levels, it is possible that you could get more power down low and possibly lose some up top due to heat depending on your setup.
07ZEKE
Aug 23, 2021 09:15 PM
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Tochigi_236
Sep 27, 2015 03:40 PM
