possible backpressure solution?
Old Aug 28, 2006 | 08:20 PM
tig488's Avatar
tig488
Default possible backpressure solution?
ive got an idea to check and see if the exhaust backpressure is the true culprit to the boost drop. ive got an extra turbo downpipe for the aps kit, what i plan to do is have a 2.5" electronic cutout installed right at the turbo. the downpipe kinda curves in front of the turbine so im gonna try to get it welded up straight in the line of the exhaust gases so they shoot right out.
its gonna be before the 02 sensors and my WB, will this cause me problems with the AFR and my 02 sensors?
Old Aug 28, 2006 | 09:00 PM
beastie's Avatar
beastie
Tig,
Sorry I am missing something. What is different than just dropping the exhaust after the down pipe? Which we both did (I think) and little improvement.
Old Aug 28, 2006 | 09:20 PM
georgec's Avatar
georgec
Would be far easier to just measure the ex back pressure imo.
Old Aug 28, 2006 | 09:21 PM
Weqster's Avatar
Weqster
boost pressure is dropping on a 2.5" downpipe on a small gt28? doubt it. id look at a better boost controller..
also what u plan do to will expose the cutout to temps way beyonds its recommended range IMO. Also u are cutting out ur wideband/o2 sensor so u will cause a few cels to be throw and possibly put off ur partial throttle tune cause the ecu will be confused.
Old Aug 29, 2006 | 04:11 AM
tig488's Avatar
tig488
beastie, i think that the part causing all the problems is the pipe bolted directly to the tubro which has the 02 sensors in it. i can drop that pipe. i dropped the curved pipe.
weqster, 2.5" dp? gt28? ive got the single kit not the twins.
Old Aug 29, 2006 | 05:13 AM
chimmike's Avatar
chimmike
don't put the cutout before the o2 sensors.
Old Aug 29, 2006 | 06:34 AM
tig488's Avatar
tig488
therein lies the problem i was afraid of.
Old Aug 29, 2006 | 07:22 AM
wtf no turbo's Avatar
wtf no turbo
Downpipe is 3.5 is it not tig? And its a gt35 not a 28. Run open exhaust on the dyno and you will see a difference at least i did. Should have bought my exhaust....
Old Aug 29, 2006 | 08:33 AM
tig488's Avatar
tig488
dave, when can you ship those other parts to me, i think im gonna need them pretty soon. just say when and ill send the money.
Old Aug 29, 2006 | 08:43 PM
Weqster's Avatar
Weqster
my bad, didnt know it wa sa single
Old Aug 30, 2006 | 05:58 PM
tig488's Avatar
tig488
so i took my car to get the exhaust backpressure tested today, and exactly as i susptected, i had almost NO backpressure, at 2500rpms the needle barely moved off zero, i revved it to 6500, and got 0.5 lbs, so i guess my exhaust is free flowing. on to other possible causes.
Old Aug 30, 2006 | 06:24 PM
georgec's Avatar
georgec
You won't see the real back prerssure figures unless you're under full engine load.
Old Aug 30, 2006 | 06:32 PM
tig488's Avatar
tig488
how the hell can you measure that, on a dyno? thats gotta be a PITA to check it like that on a dyno.
im glad i wasted that GD $35!
norrix420
350Z Roadster
May 23, 2022 05:11 PM
Uriyo_
Sep 8, 2021 08:46 AM
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
hardwood66
Sep 8, 2015 04:31 AM
