Finally, all the SAGA gauges have arrived and installed
Old Sep 19, 2006 | 07:42 PM
synth19's Avatar
synth19
oil temp, oil pressure, boost (aka "turbo" for saga).
Originally Posted by azula
synth which ones did you get? turbo, oil temp, and oil pressure? i ordered the a/f one not realizing it wasn't a wideband, so i'ma return it and get another one....lookin good.
Old Sep 20, 2006 | 04:47 AM
CarlosCh's Avatar
CarlosCh
Thanks about the info... it kind of sucks though... I like the little comp thing on the first pod
I wonder if some sort of relocation would be possible for it... has someone tried??
C.
Originally Posted by synth19
I know the saga gauges came with all the sensors needed. If you're going to change the stock gauges, change them ALL. It will look much more cleaner imo. Besides, you cannot change only the first gauge, you can only do the first two, the last one, or all three....The first two gauges are on the same circuit board, possible to change out the voltage as you can see it's just hooked up via some sort of jumper cable
Old Sep 20, 2006 | 06:40 AM
synth19's Avatar
synth19
^ honestly, it's nice... but you can live without it (especially if you no longer have your TPS with aftermarket wheels). The only thing I wish I had was outside temp, but a quick check on the radio solves that problem. I NEVER used anything else before, so I had no issues removing it.
350z82
Oct 1, 2015 06:25 PM
