Motor build up questions.
Old Sep 6, 2006 | 12:31 AM
Everybodywildou's Avatar
Everybodywildou
Default Motor build up questions.
Alright so after doing a little research, I think that if I do decide to go FI, I'll be changing some internals on a motor. There is also a possibility that I just might go all NA out and get some high compression pistons and agressive cams and whatnot. But I basically plan on getting new pistons, rods, and studs and then rehoning the block. I guess my question is, which vq35de engine can I use on my 350z? I can basically use any (quest,altima,g35,fx35,maxima, etc etc...)? If cant use all of them please let me know which ones. Sooner or later I will be looking for another engine to work on.
Old Sep 6, 2006 | 03:22 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
None of the FWD motors will work(ie: altima, maxima, etc) because the block has different mounting points for the motor mounts.
Old Sep 6, 2006 | 04:45 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
there are plenty of Z ang G short blocks for sale if you look in the right spot, i have a full long block right here for 1500 if you are in the florida area..
pm me if interested.
Old Sep 6, 2006 | 05:34 AM
Julian@MRC's Avatar
Julian@MRC
We usually have a few block lying around ready to build or already built..IMHOO going N/A with high compression is not the way to go, you will be very prone to detonate on pump gas and will not make the power you can make going F/I. Stop in or give us a shout for some of your options...
Old Sep 6, 2006 | 05:36 AM
chimmike's Avatar
chimmike
Jeremy, I've spoken with our buddy regarding that $1500 motor, we've worked something out, so consider if off de marquet
Old Sep 6, 2006 | 05:43 AM
Audible Mayhem
My350z
i love layaway plans!!
how come i get stuck with the storage for it and dont get anything??
Old Sep 6, 2006 | 01:30 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Any RWD VQ35 will work just fine.
If we can help you with forged parts, or hard engine parts...feel free.
Old Sep 6, 2006 | 01:36 PM
Nismo350ZRT's Avatar
Nismo350ZRT
Does anybody know yet with 100% certainty that the non-revup and revup blocks are exactly the same? Can you bolt a set of revup heads on a built 03-05 block?
Old Sep 6, 2006 | 01:50 PM
TENGAI's Avatar
TENGAI
Good question... Anyone?
Old Sep 6, 2006 | 03:29 PM
Sharif@Forged
Forged Performance
Yes, the blocks are physically the same...externally. Rev Up heads or non-rev up heads will bolt right up.
Old Sep 6, 2006 | 04:52 PM
Everybodywildou
The man always knows his stuff. Do you know if our stock sleeves are aluminum or iron? And do our timing chains need replacing?
Old Sep 6, 2006 | 05:22 PM
Julian@MRC's Avatar
Julian@MRC
The block, sleeves and heads are made from aluminum. Timing chain is good and we have yet to replace one..
Old Sep 6, 2006 | 05:43 PM
IslandZavage's Avatar
IslandZavage
thnkx
Old Sep 6, 2006 | 08:13 PM
Nismo350ZRT
Excellent! Thanks Sharif. Time for a built shortblock.
Old Sep 6, 2006 | 09:24 PM
Everybodywildou
Thanks for answering my questions. Whens dyno day again? This sunday right? Me and a couple of buddies are thinking about stopping in.
Old Sep 7, 2006 | 05:37 AM
Julian@MRC's Avatar
Julian@MRC
Yup this sunday..
https://my350z.com/forum/north-east/214952-mrc-motorsports-annual-fall-bbq-dyno-day.html
Stop in, Ill take you for a ride in my car, 600hp and a bad tranny..lol
Old Sep 7, 2006 | 08:28 AM
Sharif@Forged
Forged Performance
Actually, the cylinder walls (liners) are made from iron. The outer walls of the cylinder are aluminum, but the inner sleeve is made from iron, and pressed into place. Full Aluminum sleeves would never hold up to the stresses.
350Z_Al
Oct 29, 2020 07:44 PM
