APS Gurus NEED HELP!!!
Old Sep 11, 2006 | 07:22 AM
USED's Avatar
USED
Originally Posted by sugarspunZ
GT Motorsport. i have faith that Sam can figure it out
Most def
Old Sep 11, 2006 | 07:51 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
These APS single T boost drops are very aggrevating to many shops and customers. We too, have had 3 APS single T cars demonstrate this boost drop issues. We spent about 10 hours trouble shooting a customer's APS single T, and tried everything that has been mentioned in this thread, and more. The only thing we succeeding in doing, is getting more peak boost, but the drop-off pattern was identical.
Not really sure what else can be done. We've tried springs, shimming, shortening, two different styles of boost controller, no exhaust...you name it..we tried it. Best of luck, but its going to be a challenge.
FYI: Unless you are plotting boost on a dyno, it is sometimes difficult to tell that you are actually loosing boost pressure.
Old Sep 11, 2006 | 09:00 AM
tig488's Avatar
tig488
i agree, peak boost is increased but it still drops off to the same number, its like the car is fighting the boost.
most people say they dont lose boost but it is hard to tell unless you log it, mine seemed fine for a while, then i dynod and logged it and noticed it was still dropping bad.
Old Sep 11, 2006 | 09:02 AM
tig488's Avatar
tig488
Originally Posted by USED
9-15? I was told it was an 11 psi spring. In any case, it was the stronger one.
forge sends 4 springs, a 5-9 green, 9-15 yellow, 12-19 red, 17-25 blue. not sure about the last 2 but the the one im using is the 9-15psi range. i might try what you did and cut the threads down a little. i tightened it as far as it would go but it ran out of thread.
Old Sep 11, 2006 | 09:31 AM
dirtroad's Avatar
dirtroad
What is really strange is that when the kit was on my car (I sold it to sugarspun), i did not have this issue at all. I was at 8 psi at redline. Same exhaust.
Old Sep 11, 2006 | 09:38 AM
tig488's Avatar
tig488
hmm, since the kit has been installed, taken off, reinstalled, im leaning towards a busted flex joint on top of the tranny.
Old Sep 11, 2006 | 09:55 AM
Sharif@Forged
Forged Performance
You would probably hear an exhaust leak, and definately see the soot. Worth a look.
Old Sep 11, 2006 | 10:03 AM
tig488's Avatar
tig488
i never did hear the leak, i finally looked at it and saw all the soot. i guess with it being right there are the motor/tranny, its hard to hear.
Old Sep 11, 2006 | 01:43 PM
sugarspunZ's Avatar
sugarspunZ
that sounds bad.
also another thing i didnt mention. the kit is used. the kit was working just fine on the guys car that i purchased it from. he was peaking at 10 psi and tappered down to 7.5 at redline. he made 398whp and 401tq. I have all of his parts except the plenum. that i purchased new from you.
Old Sep 11, 2006 | 01:44 PM
sugarspunZ's Avatar
sugarspunZ
what does an exhaust leak sound like?
Old Sep 11, 2006 | 02:12 PM
Sharif@Forged
Forged Performance
Just a loud fluttering noise...but will also see black soot around the area that is leaking.
Oh, so now you are blaming me for the boost drop...due to the APS plenum I sold you? haha...just kidding.
Old Sep 11, 2006 | 02:16 PM
XBS's Avatar
XBS
Veteran
Are people still having this problem even with a HKS EVC 5 Boost controller?
Old Sep 11, 2006 | 02:20 PM
sugarspunZ's Avatar
sugarspunZ
hahhhaaa nah. i was just stateing that the plenum is new.
Old Sep 11, 2006 | 02:51 PM
tig488's Avatar
tig488
just look behind the motor from the top, behind the throttle body, and look down onto the transmission, if its leaking the transmission will look black.
Old Sep 11, 2006 | 05:48 PM
beastie's Avatar
beastie
Sorry to hear that... I have the same problem too so I am putting on a Greddy TT. Expensive solution, I know...
Old Sep 11, 2006 | 06:13 PM
wild121's Avatar
wild121
Ive heard a lot of problems with the APS ST loosing boost. Kinda scary.
Old Sep 11, 2006 | 07:46 PM
sugarspunZ's Avatar
sugarspunZ
i am thinking more and more that i am f--ked.
Old Sep 11, 2006 | 07:58 PM
  #38
Beer Goggles's Avatar
Beer Goggles
I'd have to say there has to be a leak or vaccum line that's leaking to cause it to open the WG even with an EBC?
Shouldn't the stock kit taper off like most kits do?
Old Sep 11, 2006 | 07:59 PM
  #39
XBS's Avatar
XBS
Veteran
What type of BC do u have?
Old Sep 11, 2006 | 08:06 PM
  #40
Beer Goggles
I'm going to think out loud. If the WG is controlled by vaccum and it is opening early, doesn't that mean that it's reading higher than it really is. If so wouldn't a clogged line or maybe kinked or melted line that may be okay until the vacuum picks up a bit cause higher readings and open the WG.
Like sticking a sock in a vacuum... it creates more suction?
