tn kit+440cc ts reflash or emange?
Old Oct 2, 2006 | 10:35 AM
speedlimits's Avatar
speedlimits
Default tn kit+440cc ts reflash or emange?
hi
what is a better combo for a tn kit with 440cc injectors
the TS reflash or emange blue?
other mods in the car are just kinetix ssv manifold and invidia n1 exhaust
thanks in advance!
Old Oct 2, 2006 | 10:40 AM
chimmike's Avatar
chimmike
reflash>Eblue in that it's plug and play, no tuning required. Only way I'd go other than reflash is with 550s and a UTEC with a CJM fuel return system and walbro pump. You'll wanna ditch that SSV, it's more a show piece than anything.
Old Oct 2, 2006 | 11:04 AM
speedlimits
ok, got it
is the ts reflash better than the tn reflash?
Old Oct 2, 2006 | 11:17 AM
chimmike's Avatar
chimmike
the ts reflash won't work on the turbo setup without using something like the UTEC.
only the TN reflash is meant to work with the TN kit.
Old Oct 2, 2006 | 11:50 AM
lemansz20's Avatar
lemansz20
ONNLLLYYYY reason I say go with the emanage is b/c you can tune it whenever you want and its not a bad ecu. Not the best(I have a utec lol), but it definately is a better choice so that you can tune it whenever you get another mod. You wont have to send out your ecu and have your car down.
Old Oct 2, 2006 | 11:58 AM
chimmike's Avatar
chimmike
I'm runnin on the stock TN reflash and I have exhaust and a plenum spacer and my A/f ratios hover around 11:1 at full boost. Perfectly safe.
Old Oct 2, 2006 | 12:22 PM
captj3's Avatar
captj3
So your saying the emanage is better than the utec?? With a lap top and the right knowledge you can tune the utec just as easy. The utec is a much better em than the emanage imo, plus it won't burn out your coils.
Old Oct 2, 2006 | 12:27 PM
chimmike's Avatar
chimmike
no, he didn't say emanage is better than UTEC we all know it is.
Old Oct 2, 2006 | 01:46 PM
Peking's Avatar
Peking
Technosquare made the re-flash program for the Turbonetics Kit. So yes you can contact TS and get them to program your ECU...
To the starter of the thread, are you buying this kit used? Cause if new, flash program is included with the price (unless you are getting the Tuner Version)...
Anywho if going for a used kit I would say go for either the Greddy E-Manage Ultimate or fork out a little more for the TurboXS UTEC.
You can find Ultimate's in the classifieds and any tuner who can do the E-Manage Blue should be able to tune on the Ultimate as well.
Old Oct 2, 2006 | 01:49 PM
speedlimits
its used. im out of budget right now so i might just use the emanage blue coz much more cheaper than EU.
but do u think its safer just to use some 380cc injectors and get my ecu reflashed at turbonetics or ts?
much more no hassle i guess than using some 440cc and tuning the emange blue right?
Old Oct 2, 2006 | 01:58 PM
MIAPLAYA's Avatar
MIAPLAYA
I would choose the EU at the minimum if you are on a budget. If you can't afford it now I would wait on install till you could at the least afford that.
Old Oct 2, 2006 | 02:05 PM
speedlimits
thanks
i might just go for 380cc and ts/tn reflash
for no hassle as of now
Old Oct 3, 2006 | 09:00 PM
znot's Avatar
znot
very good to hear as i'm about to install a used tn st kit onto my 04 6mt sedan, just waiting for +1 colder plugs, walbro pump and extra heat wraps......i have the 1/2" md spacer and unothodox crank pulley and stock exhuast.....hopefully, it'll be at or near 11:1 as well...........
Old Oct 3, 2006 | 10:35 PM
taurran's Avatar
taurran
That totally depends on if the person that installs the kit modifies the stock FPR correctly.
Old Oct 4, 2006 | 06:28 AM
chimmike's Avatar
chimmike
I absolutely dislike EU because of the fact that it fries coilpacks. I'd avoid using it if at all possible.
Old Oct 4, 2006 | 06:36 AM
ipcheck's Avatar
ipcheck
same for me,
TN kit
atmosphere dump
wrapped pipes
kinnetix V plenum
pulleys
straight 3" ehxuast
no inlet pipe on the turbo
ssqv blow off
alphawerk headers...
and WOT = 11.1...
Old Oct 4, 2006 | 06:59 AM
lemansz20's Avatar
lemansz20
No NO lol I was saying that I have the utec. The utec if you can get it is awesome b/c how exact you can tune it and stuff. I dont like the flash b/c if you ever get another mod, MOST of the time you have to have your car down for a few days. Reason being you have to take the ecu out and have it reflashed, where as using an emanage you can install the part and tune the car on the spot and have no down time.
Old Oct 4, 2006 | 04:48 PM
solidsnake's Avatar
solidsnake
Originally Posted by ipcheck
same for me,
TN kit
atmosphere dump
wrapped pipes
kinnetix V plenum
pulleys
straight 3" ehxuast
ssqv blow off
and WOT = 11.1...
Thats unfair. Ive got exhaust, 5/16 spacer and Im running 10.5 at WOT. You, taurran and miaplaya all have perfect 11's. Would a re-reflash help me out?
Old Oct 4, 2006 | 05:37 PM
doug's Avatar
doug
throw up on yourself
Old Oct 15, 2006 | 12:49 PM
TayTaythatsme04's Avatar
TayTaythatsme04
had to bring this back had some related ?'s, so you dont need the TN reflash really.
Because I have a lot of bolt-ons and im planning on using the Utec, should I just skip the reflash all together
BTW the kit is used
Thanks
T
