Vortech only boosting 4psi
Old Oct 8, 2006 | 02:20 AM
silver nismo's Avatar
silver nismo
All the above.....
a) belt sliping.
b) vacume leak and u should b able to hear it if u listen close enough.
c) check the bie bass that leads to ur gage.. unless u dont feel power at all.
Old Oct 19, 2006 | 09:50 AM
Alang's Avatar
Alang
VRT seems to have fixed the problem. Replaced the Kinetix plenum with stock and the boost is now where it should be. Tuning next week, I hope, and I will finally have some numbers.
Old Oct 19, 2006 | 09:59 AM
teh215's Avatar
teh215
Are you sure that the Kinetix plenum was not cracked?
Old Oct 19, 2006 | 10:14 AM
sentry65's Avatar
sentry65
the burninator
this is the kinetix V5 plenum we're talking about right?
Old Oct 19, 2006 | 12:51 PM
Alang's Avatar
Alang
Its the latest version, and there are no apparent cracks. It idled smmoth as silk with it on, and never stumbled. If I had to guess I would say it was a gasket (I've heard of this before), but I wasn't there when it was changed out, so I do not know for sure.
Old Oct 19, 2006 | 01:13 PM
MIAPLAYA's Avatar
MIAPLAYA
A friend of mine had this happen on his G35 with the Crawford plenum. He was idling fine but when he boosted the car would go stupid lean and ping a bit and then one day stopped boosting as much. Found out that the plenum was warped and causing air leaks. Even his vacuum was fine. Switched to stock and it worked great.
Old Oct 19, 2006 | 03:37 PM
booger's Avatar
booger
Same here...no vacuum leaks , but when I preasurized the whole system , found boost leaks all over the plenum . I added more gaskets and no more leaks
Old Oct 20, 2006 | 09:27 PM
mraturbo's Avatar
mraturbo
Alang,
Car runs great.
Looking forward to seeing you at Calspeedway.
M
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
