Injector issues. Anyone install their own CJM fuel system??
Old Oct 15, 2006 | 01:02 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Default Injector issues. Anyone install their own CJM fuel system??
I'm installing my CJM fuel return system, but i'm stuck. Can someone tell me what i'm doing wrong? I'm not sure if these 440 injectors i have are the correct ones or not? I can take more pictures and have them posted of anything that would help someone show me the way. Here is the thread and ebay auction i bought them from. https://my350z.com/forum/showthread.php?t=220253
Notice the gap where the bolts holding down the fuel rails are. Where they are now is pretty tight. I stoped because it didn't seem right. Maybe i'm missing some washers or my injectors are too tall?
Old Oct 15, 2006 | 01:07 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Your spacers are wrong for sure.
Old Oct 15, 2006 | 01:12 PM
failsafe306's Avatar
failsafe306
and when you get the spacers right, make sure you're going to clear the lower plenum. I had to grind my lower plenum, but then again i was running 1000cc's.
Old Oct 15, 2006 | 01:18 PM
westpak's Avatar
westpak
SFZCC
The spacers look thin but also check to make sure you don't have too many orings in place, if you didn't make sure the old orings were out and put injectors with new orings you might have two instead of one.
Old Oct 15, 2006 | 01:27 PM
Nic@CiNcity
Those spacers are stock and were there when i pulled off my stock fuel rails. Was my kit supposed to come with thicker ones? The Orings are correct. Can i just use a few extra washers?
After PMing the seller of my injectors, he said i needed clips to make those work. For some reason i was thinking that i wouldn't need clips with an aftermarket fuel return for some reason? Maybe that was with bigger injectors or a differenct brand or something? I'm retarded. Can someone help me out with clips? I need these next day air if possible. I'll pay for it of course.
Old Oct 15, 2006 | 01:30 PM
failsafe306
Sharif sells the clips for $60 or something, try him. Your kit should've come with thicker spacers, at least my AAM kit did. You can just use some washers, that's what I did with mine.
Old Oct 15, 2006 | 01:33 PM
Nic@CiNcity
What about the rails? I'm looking for write ups on installs and stuff, but haven't had any luck yet. Notice the rail on the right is a bit longer at the end. I have a fealing that they are backwords after looking at the CJ Motorsports web site.
Edit: I just PM'd Sharif to see if i could get these clips next day air to me. As well as a few other things i need quickly. Gaskets, couplers, and a missing oil return/feed hard line for my Greddy TT kit. If anyone happens to have any of these things, mind hooking a brotha up?
Old Oct 15, 2006 | 01:37 PM
failsafe306
No they're right, they're supposed to be like that, one shorter. There isn't any other way to put them on.
Old Oct 15, 2006 | 01:51 PM
Nic@CiNcity
"If you have the stock injector clips you will need to purchase the RC injector clips for these injectors to work. If you are using the Greddy Twin Turbo Kit then you do not need the clips."
This quote is talking about the RC 440cc injectors i have. I bought my Greddy TT used w/o injectors. That's why i bought the 440's seperate that i have now. If they came from a previous kit, i don't see why they don't work... I'm stuck
Pulled this quote from here. http://www.importpartspro.com/rceninni35g3.html
Old Oct 15, 2006 | 02:05 PM
Nic@CiNcity
Maybe i'm getting "clips" confused with something else? The injectors fit correctly in the rails and in the motor. No issue there except the spacers are small and i'll need to add some washers. What i'm concered with is in picture 2 and 3. The male and female connectors are different shape. New 440 Injectors are square and the stock connectors to hook them up are round.. WTF? Or will a "clip" fix this? Help
Old Oct 15, 2006 | 02:22 PM
failsafe306
You'll have to cut the OEM "clips"-the injector plugs- off, and solder/tape the RC ones on. Then get some washers to that you don't crush your o-rings when you tighten down the rails, and you'll be all set.
Old Oct 15, 2006 | 02:37 PM
Nic@CiNcity
ohhhh... Makes sence. Then what's all that business about that quote i posted about Greddy TT kit guys don't need clips to make them work?
Old Oct 15, 2006 | 02:40 PM
failsafe306
Cause the Greddy injectors fit the OEM harness.
Old Oct 15, 2006 | 02:49 PM
Nic@CiNcity
Edit.
Old Oct 15, 2006 | 02:53 PM
Gary King's Avatar
Gary King
GReddy TT kits come with new clips for the RC injectors that are also included in the kit. We're now a GReddy authorized dealer, If GReddy has the parts you need Subrwho, I should be able to have them overnighted to you, just let me know what else you need. I may be able to get spacers for you too as the GReddy TT kit's come with those also.
Old Oct 15, 2006 | 02:57 PM
Gary King's Avatar
Gary King
If you don't believe me you can ask Sharif at Forged and he'll tell you the same thing, he's who I ordered that kit through before we became an authorized GReddy dealer. I'm sorry you're frustrated but, I'm trying to help you, no need to slam me on the boards.
Originally Posted by Subrwho
According to Gary King (forum member i listed in my first post) of "G Rides", these WERE from a Greddy TT kit for a 350z. But.. obviously they are not. I sent him a PM with a link to this thread so hopfully he'll see this and help me out. Maybe trade these out for the ones i thought i was buying? BTW, thanks for your help Failsafe
Old Oct 15, 2006 | 03:01 PM
Nic@CiNcity
Ah sweet! Thanks! I need these things like yesturday. While i have you here, are you able to get ahold of a complete gasket kit for the Greddy TT? I'd rather not reuse the ones from my used TT kit i just bought. Also looking for four 3" exhaust flanges and two 3" gaskets as well as a hard oil return/feed line that connects to the turbo. One turbo came with a hard line that was pretty long and sort of a crooked Z shape. I believe the one i'm missing for the other turbo is a bit shorter?
Old Oct 15, 2006 | 03:04 PM
Nic@CiNcity
Oh no.. Wasn't looking to slam you, infact i was very happy with how you do business. I just had mixed information on what i needed. I'd recomend you and your shop any day of the week. Infact those business cards you sent with my injectors have already been distributed
Old Oct 15, 2006 | 03:25 PM
Gary King's Avatar
Gary King
No worries Subrwho, I understand we're your coming from, you just want your project to go smooth and then, Ohhhh what the @$%*? I'll do everything I can to help get you back up and running ASAP.
Thanks for spreading the word about us UP North!! Oh and the feedback you left us on EBay was Top Shelf.
Gary
Old Oct 15, 2006 | 04:11 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Everything all sorted out? Use the RC spacers included with the greddy kit, or the injectors. I have RC injector clips if you need them..just let me know.
Or Gary can get them for you...all good.
