BamBam's Update: The Boost is Loose at Forged Peformance!
Old Oct 27, 2006 | 10:45 AM
  #141
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Yes
Originally Posted by PumpedVA
Is this the Z you guys had at HIN DC last year?
Old Oct 27, 2006 | 11:12 AM
  #142
350Zzzz's Avatar
350Zzzz
Professional
What exhaust and down/mid pipes are you using?
G
Old Oct 27, 2006 | 11:21 AM
  #143
JCZ33's Avatar
JCZ33
OK Sharif, I just hit the LOTTO, I want 1000HP, how much$?
Good job on the ZR!
Old Oct 27, 2006 | 11:35 AM
  #144
HoldThisForMe's Avatar
HoldThisForMe
Good job on the ZR!
im not Sharif but spend atleast ~20k on the motor
Old Oct 27, 2006 | 11:45 AM
  #145
InjectedPerf
It is all custom made as our turbo kit is completely custom. It does have the Vibrant Muffler as it seemed to have the best flow through and diameter piping at the time.
G
Old Oct 27, 2006 | 12:41 PM
  #146
Gman2004's Avatar
Gman2004
more than that.
$10,000 motor
$5,500 basic Greddy TT
$2,200 AAM stage 1 and stage 2 fuel systems
$3,500 FCON/Knock Amp and harnesses
$700 AAM 3" test pipes and dumps
$1,500 AAM 3" exhaust
$2,400 ATS twin disc clutch
$25,800 and that's not even including labor, tuning, gauges, or even the cost to upgrade the stock greddy turbos.
Old Oct 27, 2006 | 01:13 PM
  #147
symalik's Avatar
symalik
i think he meant to say $20k JUST on the motor and no other parts
Old Oct 27, 2006 | 01:17 PM
  #148
Gman2004's Avatar
Gman2004
then he is way high. Brent's motor doesn't cost $20K. You can get the new GTM stroker kit with stage 4 heads for less than $20K.
Old Oct 27, 2006 | 01:24 PM
  #149
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Gman2004
more than that.
$10,000 motor
ATS/Carbonetic Triple for those power goals...about $2800
Old Oct 27, 2006 | 03:28 PM
  #150
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It does add up quickly...but when done right, you have greater-than-supercar power at a relative bargain. And the 350Z/G35 still turns more heads than most supercars, and are classy enough to attend a formal function.
Old Oct 27, 2006 | 03:31 PM
  #151
BobbyRitz's Avatar
BobbyRitz
more than that.
$10,000 motor
Good looking list with a few exceptions.
I'd go with 3.5" APS test pipes, Forged open dumps, APS Xtreme fuel return or CJ Motorsports fuel return and an APS 3" exhaust.
But that's just me!
Old Oct 27, 2006 | 03:52 PM
  #152
JCZ33's Avatar
JCZ33
It would have to be a stroker kit and maybe even the Cosworth heads; does a cam set with come with the cosworth heads?
Old Oct 27, 2006 | 03:55 PM
  #153
Sharif@Forged
Forged Performance
Cams are always seperate, and are added to the complete head. With so many camshafts out there, we dont bundle them together. We can work out a package deal with camshafts if that is something you are interested in.
Old Oct 27, 2006 | 04:14 PM
  #154
HoldThisForMe
yeah i was saying just motor...
8900 for built stroker
4289 for cosworth heads
1300 cams
ok thats close to 15k lol just add 2500 for ats triple and if you go crazy with custom titanium rods then you will be pretty darn close to 20k...im sure it could be done for the ULTIMATE motor for 1000hp hehe
Old Oct 27, 2006 | 04:53 PM
  #155
Gman2004's Avatar
Gman2004
But that's just me!
the only thing is the 3.5" aps tp's won't bolt up to the greddy turbos, but since most of what you listed was aps I'd assume you'd go with the aps tt as well. Nice list none the less.
Old Oct 27, 2006 | 04:59 PM
  #156
BobbyRitz's Avatar
BobbyRitz
nah...I'm a greddy guy...if I decide to go turbo. I'm not necessarily an APS fan either, just based on your list I'd opt for a few different parts...
Old Oct 27, 2006 | 05:15 PM
  #157
Gumpdriver's Avatar
Gumpdriver
The number def add up fast as hell. I have to do a couple of months of saveing now. Just to do big things.
Old Oct 27, 2006 | 05:19 PM
  #158
JCZ33's Avatar
JCZ33
1300 cams
WOW!!! That's the way!
Old Oct 27, 2006 | 05:21 PM
  #159
BobbyRitz's Avatar
BobbyRitz
Sharif-
This is the first built Greddy kit that I've seen (or better yet, read about) that has decided to up the boost to 23lbs. You used C18 race fuel for the final tune at that boost level.
Was this a conservative measure with slightly more aggressive timing (due to the C18) or could the owner of a built motor readily run at 23lbs on 93 octane with the same ignition timing curve?
Old Oct 27, 2006 | 05:23 PM
  #160
Alberto's Avatar
Alberto
Cranky FI Owner
23lbs on 93 octane is a no no.
