ForgedPerformance Tuned FCON Stock block
Old Oct 29, 2006 | 04:06 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Originally Posted by Sharif@Forged
Eagle, didnt you say that your old trap speed was 116mph?? And now with the FCON the max was 121mph? Maybe I misheard you.
Correct My averge trap was 116 with the UTEC, my highest trap with the FCON is 121. With these street tires every pass seem to be diffrent as far as traction is concern, so traps are going to very.
Old Oct 29, 2006 | 04:16 PM
Julian@MRC's Avatar
Julian@MRC
Get some sticky tires, youll see a 11.5-11.9 pass with a good launch..We were running 445 DJ STD WHP on our stock motor Z with the old Unichip and would see 12.1-11.9' on stree tires, then go to 11.4-11.6's with DR's and a 1.7-1.8 60's..Our traps were always in the 119-122 range with that HP..Keep at it, the 1/4 mile is HARD to master..
Old Oct 29, 2006 | 04:57 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Do I have to kill some to become part of the "Premier Mafia"
You need to pwn a couple of Newbs! And then you can post it up onto your sig!
Old Oct 29, 2006 | 07:27 PM
JETPILOT's Avatar
JETPILOT
The temperature difference you note is unimportant. The DynoDynamics takes into account temp and pressure when making hp calculations. The DynoDynamics spits out temp and pressure corrected numbers. This was the same dyno or was the previous dyno @ CP Racing?
JET
Old Oct 30, 2006 | 11:36 AM
eagletanggreen
Got Track!!!!!
JET
This was done on the same dyno at ForgedPerfomance "The Heart Breaker". Maybe Sharif can chime in about this, to explain it better.
Old Oct 30, 2006 | 11:43 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The slightly lower power is due to two things.
1) Aftermarket wheels/tires vs. the 17 inch skiny stockers used on the prior tuning session
2) I reviewed the logs, and the inlet probe was touching a hotter surface, and added about 4-5% more to his previous number.
All and all, Eagle's engine probably made the same power with the UTEC and the FCON....but the driving results and experience is much better now.
Old Oct 30, 2006 | 12:13 PM
al v's Avatar
al v
Sharif , I sent you a PM............
Old Oct 30, 2006 | 12:30 PM
__jb's Avatar
__jb
Z + Rear Seat
The point Eagle is trying to make, is that the smoothless and precision of the FCON, is allowing him to make higher speed passes at the track. You have to drive them before and after to truly appreciate the difference. I am sure Eagle can better describe his first test drive the FCON...even though the engine was making the same peak power as the UTEC.
Thanks for the explanation, Sharif.
A five mile an hour increase in trap speed is an amazing increase.
Old Oct 30, 2006 | 01:26 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Not fair to compare avg of UTEC to best of the FCON. Eagle-what were your best traps for both units?
Old Oct 30, 2006 | 04:36 PM
eagletanggreen
Got Track!!!!!
I did trap 119 once on the UTEC after that the best trap I saw was 116. With the FCON I have seen 121 at 50degrees once, and have been averaging around 118 to 119 in 66 to 72 degrees.
Old Oct 30, 2006 | 05:00 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Very nice-that car is pulling strong....
Old Oct 30, 2006 | 05:36 PM
eagletanggreen
Got Track!!!!!
Let hope she keep it up till the engine build in December.
Old Oct 30, 2006 | 07:36 PM
Mc556's Avatar
Mc556
Were you the silver Z on the dyno late friday night? If so I was one of the two guys that showed up late that night before the efi 101 deal. What track do you go to maybe you can do a pass or two on my drag radials i'm in Greenville.
Old Oct 30, 2006 | 09:10 PM
thawk408's Avatar
thawk408
I believe you are talking about me. The one that the e01 took a crap on?
Old Oct 30, 2006 | 10:03 PM
Mc556's Avatar
Mc556
Probley so that sucks. fun class though.
Old Oct 30, 2006 | 11:37 PM
silver nismo's Avatar
silver nismo
Originally Posted by Acree
Wait, what's the difference between slicks and drag radials?
Also, what is the stickiest tire you can get away with on the street? I don't mean what will pass inspection or a look see from a cop, but what tire is ok to drive on the highway, and also net low low 60' times?
@Eagle - Congrats and seriously amazing numbers!
-Acree
Michlen are scarry on road a friend of mine is 460 whp and he has them he does a roll on 60 kph = 35 or 38 mph and floor it not a single spin. sorry for the thread intruption. congrats man realy nice to see u enjoying the drive 20 or 30 or 40 whp less is nothing if u dont have a nice drivable car. well don on the drag as well and now get them sliks u need them. Good luck.
Old Oct 31, 2006 | 07:15 AM
Julian@MRC's Avatar
Julian@MRC
1) Aftermarket wheels/tires vs. the 17 inch skiny stockers used on the prior tuning session:
Shouldnt make that big of a difference, a few HP at best but the unsprung weight of the 19's will really come into play from a dead stop, like at the track..It will shave off speed and et from the weight and the loss of HP from spinning the extra weight..Another thing to consider when looking at trap speeds, is the 60ft and traction off the line..Some times I run faster ET's with lower traps, lower by like 3-5 MPH..You can achieve a higher Trap speed by spinning off the line..A good comparison, it to observe the old domestic cars run.They leave the line with 1.50 60 fts and run 10.70-10.90's with a 120-123 trap. The gearing and traction on those cars is dialed in to go from A to B as fast as possible..In my car Ill trap 126-128 and run 11.6-11.9's..
I know about that darn Temp probe jacking numbers up, happened to me..
Another thing to check is make sure the barometer readings were consistant, we experienced some weird stuff with a low pressure barometer reading..The temp corrections should hover in the area of .9's and 1.1's during extreme variances in ambient tempuratures...So make sure you look at the Atmoshperic correction values on the DD from the previous #'s to the last #'s..We found that a dead battery in the weather station would make a 70whp difference
I agree....However for the price difference, a properly tuned UTEC with all load points carefully tuned on a load based dyno, would be comparable to the tune achived from the much more expensive FCON. The Comarison I would make is if the UTEC were a Mercedes Benz, the FCON would be a Bently...They both achieve getting the owner from A to B, but its how you get there.. If you have the money to drop, the FCON is a better unit.However the UTEC's resolution is only limited by the type of interface it uses, HYPERTERMINAL...In the new version of windows based software the UTEC will have better resolution,more features,and better GUI..These additions IMO will puyt it right on par with the big boys for half the money..
Old Oct 31, 2006 | 07:49 AM
  #38
BrianLG35C's Avatar
BrianLG35C
When do you expect it will be available?
Old Oct 31, 2006 | 07:51 AM
  #39
350zDCalb's Avatar
350zDCalb
builtZmotors
when is this coming out? is there a link to this?
Thanks
TODD
Old Oct 31, 2006 | 09:23 AM
  #40
projectsherv's Avatar
projectsherv
I am also interested to see when this new software is going to be released, or is it already available?
