Boost,egt,oil pressure gauge???
Old Nov 15, 2006 | 08:23 PM
bgsean42's Avatar
bgsean42
Default Boost,egt,oil pressure gauge???
have the defi blue racer series boost,egt,oil pressure gauges and i am want to install them myself! my problem is where do i connect the power cords to the gauges i have them in my a pillar. thanks any help would work i have an o3 g35 coupe though
Old Nov 15, 2006 | 08:26 PM
MIAPLAYA's Avatar
MIAPLAYA
I tapped power for my gauges from a red and black wire under the dash in the drivers side foot well.
Old Nov 15, 2006 | 08:35 PM
bgsean42's Avatar
bgsean42
what gauges did you wind up usesing and did you connect the signal side of the gauge yourself?
Old Nov 15, 2006 | 08:37 PM
MIAPLAYA's Avatar
MIAPLAYA
I used all Autometer units. And me and protocav did the gauge wiring yes.
Old Nov 16, 2006 | 07:31 AM
bgsean42's Avatar
bgsean42
th eonly problem i see myself having is connecting the egt gauge.... i dont have a lift so i can not see if i have bungs on my headers i should and i think i do but either way i cant get to them to install the egt bung connector but i have the oil sandwhich plate and as well as the boost gauge is easy...
Old Nov 16, 2006 | 07:35 AM
MIAPLAYA's Avatar
MIAPLAYA
Where are you located?
Old Nov 16, 2006 | 11:08 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Where did you get the oil sandwich plate?
Dave
Old Nov 16, 2006 | 11:10 AM
MIAPLAYA's Avatar
MIAPLAYA
Dave
Mocal makes one SPF1T I believe is that part number. Nissan Motorsports USA also makes one that replaces the stock ring so coolant no longer runs through there. I think www.theexperience.com has them. www.gspec.com might have them too.
Old Nov 16, 2006 | 11:26 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Actually, I was being kind of obtuse. What I am looking for is a place to put in an oil temp sensor, but I allready have a Stillen Oil Cooler, which uses a sandwich plate. I was trying to figure if I could use two sandwich plates, one for the cooler, and another one for the oil temp sensor. Probably it would be too long an extension.
Any ideas?
Dave
Old Nov 16, 2006 | 11:28 AM
MIAPLAYA's Avatar
MIAPLAYA
Any ideas?
Dave
Actually thats EXACTLY what Cheston did on his car. Do a search for a post from Chebosto regarding oil coolers. he has a Mocal adaptor and a Greddy adaptor both installed.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
