Some Show and Tell...
Hmm it appears on the passenger side you are pulling coolant from the return coolant line to the radiator. Not sure if it really makes a difference but wouldn't you want to pull the cooler water from the radiator feed side?
Cheers Amy
Originally Posted by Philthy
the coolant is going to still be way cooler than the turbo temps - as you stated, it doesn't make any difference...
Doing well - happy thanksgiving...
Woke up early this morning and we got the motor/trans back into the car... Hopefully we'll finish up this weekend and start getting some miles on the car...
Here's a pic of the coolant returns...
I have a ton of pics, let me know if you want to see something specific -
Here are some of the custom ACPT carbon fiber driveshaft and the 3" exhaust...
Pyromint exhaust valves - Headgames race port & polish
Great pics philth...anymore of coolant line routing for the turbos
Crank Angle Sensor Wire Mod
There's probably a couple days work left before we get it started - and no, the exhaust doesn't touch the drive shaft... It's looks a lot closer in the pics than it actually is... The carbon drive shaft weights around 18 pounds - the stock one was around 40 pounds...
Originally Posted by Sharif@Forged
Phil, is that driveshift still an expensive one-off piece, or does that company have plans to make more. What a huge improvement over the stock G35 driveshaft.
Here's a pic of the G35 Coupe stock unit for reference... The exhaust in the pic is the Borla - I still have it and the Borla headers if anyone is interested - PM me...
