Project Supercharger
Old Nov 20, 2006 | 04:38 PM
350Z_LEE's Avatar
350Z_LEE
Default Project Supercharger
Just received my procharger kit in. Will be doing the install this weekend, so I guess I'll start a thread of the progress/results. I have the 440 cc injectors that come with the GReddy kit, and I bought a Walbro 255 fuel pump also. I am going to attempt to install the e-manage too, and I will be driving to SGP for the tune in a week or so. Stay tuned, I will post some pics and a video when it's done.
Yay
The before!
Old Nov 21, 2006 | 06:05 AM
Quamen's Avatar
Quamen
is it me or does the impeller look like it has a ton of machining marks on it?
Old Nov 21, 2006 | 08:07 AM
350Z_LEE's Avatar
350Z_LEE
I am pretty sure you can make more than 320 hp.
Old Nov 21, 2006 | 08:41 AM
jpc350z's Avatar
jpc350z
I'd be interested in what your fuel pressure is after the 440 and walbro... Mine is at around 80psi at idle and drops a little under during normal driving. Without the Turbonetics mod for the fuel pump you may end up with the same press..
Old Nov 21, 2006 | 09:15 AM
Quamen's Avatar
Quamen
You can definitly reach higher than 320whp with the procharger. The C-2 is a quite capable headunit if you ask me. There are a number of characteristics to the kit which however are design compromises and take away from the overall potential of the kit. Low 400's are possible with good tuning and a different pulley.
Old Nov 21, 2006 | 09:29 AM
savvy's Avatar
savvy
i bet that dog adds like 20whp
Old Nov 21, 2006 | 10:36 AM
mikead_99's Avatar
mikead_99
Very useful, constructive post. Why so down on procharger, or are you just an ***?
Old Nov 21, 2006 | 12:42 PM
350Z_LEE's Avatar
350Z_LEE
I am going to let SGP tune it, and I am sure they'll make some decent numbers. I plan to roll with the 7psi pulley for now and see how I like it, then if I want upgrade. I am not looking for too much power. I would like to get low 12's for now:]
Old Nov 21, 2006 | 12:56 PM
Jay'Z's Avatar
Jay'Z
Ill stay tuned to this.. please let me know how it works out..... thanks
subscribed......
Old Nov 21, 2006 | 12:57 PM
RobertH's Avatar
RobertH
i think he was literally talking about the dog. as a joke
Old Nov 21, 2006 | 01:20 PM
mikead_99's Avatar
mikead_99
Ahaha. Seems like I always say the smartest things while on damn cold medicine.
My bad, and I apologize for it.
Old Nov 21, 2006 | 02:09 PM
350Z_LEE's Avatar
350Z_LEE
Beware, that dog lives with my 2 pits and he is the boss!
Old Nov 21, 2006 | 02:16 PM
MIAPLAYA's Avatar
MIAPLAYA
Agreed. You are going to need to mod the regulator or you are going to run some ridicuous fuel pressure...
Old Nov 21, 2006 | 03:01 PM
Ep3's Avatar
Ep3
^ can u guys expand on that i run 9 psi on my procharger and see 55psi @ idle ??
Old Nov 21, 2006 | 03:06 PM
MIAPLAYA's Avatar
MIAPLAYA
Are you running a Walbro 255 lph fuel pump with no return system or stock FPR modification? The G35 sedan I believe doesn't need any modifications made to the stock FPR. But the G35C and Z if you just install a Walbro 255 lph with no modification to the stock FPR and no full return system will produce 70-80 PSI of fuel pressure at the rail..
Old Nov 21, 2006 | 04:03 PM
350Z_LEE's Avatar
350Z_LEE
I guess I may need to look into that then. ANy suggestions? WHat is the mod piece you are referring too? gracias
Old Nov 21, 2006 | 04:23 PM
Ep3's Avatar
Ep3
im running the APS TT kits return fuel system.. i guess that explaines it thanks mia
Old Nov 21, 2006 | 06:14 PM
MIAPLAYA's Avatar
MIAPLAYA
Indeed it does.
Old Nov 21, 2006 | 06:17 PM
MIAPLAYA's Avatar
MIAPLAYA
I'm attaching a link to the Turbonetics Single Turbo kit instructions. Follow Step 14 A-J and L. That should give you all you need to install the fuel pump and modify the fuel pressure regulator..
http://turboneticsownersclub.com/tur...icsinstman.pdf
Old Nov 22, 2006 | 06:53 AM
350Z_LEE's Avatar
350Z_LEE
Thanks, appreciate that Mia
