S/C Installed....Need some info
Old Dec 2, 2006 | 11:10 PM
asianflip06's Avatar
asianflip06
Smile S/C Installed....Need some info
Hey guys i just installed my Vortech SC today and was wondering if there is anyway to clock the turbo? Reason i say is the drive belt is pretty close to the supercharger and want to clock it down some to have a better clearance and so i can remove the belt later someday.... Also what is the recommended step to tighten the cog belt? Ive searched but found little info on belt tightening...I think i have to too tight because it whines really loud....haha but who knows from what i hear clunking, whining, and rattling are all normal symptoms. Ohh yah I dunno if this matters though but on my S/C it says V1 instead of the V2 SQ i usually see....Is there a difference?
Old Dec 3, 2006 | 03:37 PM
xav_350z's Avatar
xav_350z
on my s/c it says V2, btw u tuned ur z or still running on vortech's factory tune?
Old Dec 3, 2006 | 06:12 PM
booger's Avatar
booger
Did you buy the kit NEW ? It shouldnt be whinning that loud , sounds like you may not have it put together right and the belt maybe rubbing on something . I beleive you can clock the SC head on the gear box , but you would have to make different IC pipe
Old Dec 4, 2006 | 02:14 AM
xav_350z's Avatar
xav_350z
VORTECH V-1 S-TRIM SUPERCHARGER
The industry standard supercharger
Straight cut spur gear
Fits engines up to 680 horsepower
Maximum airflow: 1,000 CFM *
Maximum boost pressure: 20 PSI *
Maximum impeller speed: 50,000 RPM
Adiabatic efficiency: 72% **
VORTECH V-2 SQ SC-TRIM SUPERCHARGER
Helical cut gear profile with SQ technology
Near silent operation
Maximum impeller speed: 53,000 RPM
Adiabatic efficiency: 75% **
Available with straight or curved discharge
Old Dec 4, 2006 | 10:55 AM
asianflip06
I bought my kit used so that could explain a few things...Well i got the thing to run quieter now that i adjusted it with less tension and i also put on the filter this time....Anyone want to share me there stock maps so i can get an comparison when i hook up the r4 to the box? I will get pics up and hopefully a video so i can let you guys know how it runs...
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
