FI = Smelling like exhaust / gas
Old Dec 8, 2006 | 05:04 AM
QuadCam's Avatar
QuadCam
Originally Posted by HomieG35
When the AC is on recirculate it is worse then when its just outside air. ....
mine is worse too when the recirculator is on, too.
yesterday, I didn't have any gas smell.....the sage continues.
also, go back and look at your return system connections. check all the fittings to see if there are any small leaks, and tighten them down.
who's return system do you have? AAM or CJM? the AAM has been mentioned to "sweat" gas vapors. teh CJM uses coated hoses and professionally crimped hose ends to eliminate vapor leaks.
Old Dec 8, 2006 | 07:05 AM
AmateuRN's Avatar
AmateuRN
I have the SGP Racing return fuel sys. It hasn't bothered me as much, but now that I know other people have the same problem I'd like to figure it out... Wonder why its so much worse with the AC? How would it get into the system?
Old Dec 8, 2006 | 07:40 AM
QuadCam's Avatar
QuadCam
probably because the A/C intake is in the engine compartment.
Old Dec 9, 2006 | 07:51 AM
BobaFettm's Avatar
BobaFettm
either way... I just wanted to see if anyone else had this problem...
like I said its not really noticeable while your in it... only time my eyes have burnt was after autocrosses... but thats constant on off of gas all the time... driving they are fine! Its just the smell that gets to me after i leave
Old Dec 9, 2006 | 09:18 AM
QuadCam's Avatar
QuadCam
mine has been good for the last 3 days now. I thik my recent issue was from when I changed my fuel pressure sednign unit and gas squirted out. It must have left a puddle in the valley of the black and was slowly burning off over the next week.
Old Dec 10, 2006 | 01:16 PM
CNOTE's Avatar
CNOTE
I don't think I would enjoy driving a car that made me smell like gas/oil fumes and burned my eyes..... maybe that's just me though... to each his own?
Old Dec 10, 2006 | 09:52 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Boba, is your car running excessive rich? I know it was pretty rich at ZDAYZ, but that was before you did the return fuel system...I think.
Anyways, which RFS do you have? THe AAM's can smell a little bit. The CJM's do not.
Old Dec 10, 2006 | 10:05 PM
BobaFettm's Avatar
BobaFettm
no they fixed all that stuff... it was only rich during idle but not to an extreme... it wasnt HONDA rich at least
Old Dec 10, 2006 | 10:17 PM
Triple8Sol's Avatar
Triple8Sol
I'm yet another guy that had test pipes and couldn't stand them b/c of the smell. Swapped the stock cats back on, and problem solved.
Old Dec 11, 2006 | 06:59 AM
PumpedVA's Avatar
PumpedVA
then I need to swap my aam out because if I top my tank off its real bad
Old Dec 11, 2006 | 07:06 AM
QuadCam's Avatar
QuadCam
that sounds more like the o-ring where your fuel pump housing and tank mate up is not sealing. when you fill up, the fuel level in the tank is above the level of the the pump housing. if the o-ring isn't sealing, you get a leak.
Another thing to look at is the hole you have to drill through the pump housing for the fuel return fitting. That's another location for a potential leak.
Old Dec 11, 2006 | 09:06 AM
AReddy23's Avatar
AReddy23
i had the same problem with my tn g35. i didn't have cats and the smell would really bother me whenever i take the car out. needless to say i ended up selling it and getting a 911 carrera. i love my new car but at times i miss the sheer thrill of driving the g35, so think hard before you make a decision. maybe you can get a daily driver?
Old Dec 11, 2006 | 09:18 AM
sentry65's Avatar
sentry65
the burninator
best mod I've done has been getting a daily driver to make my Z feel that much faster. Good to have a backup car anyway
Old Dec 11, 2006 | 10:31 AM
PumpedVA's Avatar
PumpedVA
If its the 0 ring it will be the 4th time I had to replace it. Sucks!
Old Dec 11, 2006 | 01:57 PM
World Famous Z's Avatar
World Famous Z
n e one with a stillen sc have this issue? i do at wot. i think ive narrowed mine down to the 7th injector. there is a block that saces the larger injector for the stage 4 kits and mine was too big we had to shave it down. ill change that out soon to see if it is that after all. since that injector only fires at higher throttle and boost loads cruising doesnt give u that smell since that injector isnt firing...
Old Dec 11, 2006 | 02:45 PM
QuadCam's Avatar
QuadCam
Dayum!!!! I think I'va had my fuel pump housing in/out of the car about 6 times and I am still on the original gasket.....no leaking
Old Mar 22, 2007 | 01:29 PM
BobaFettm's Avatar
BobaFettm
Okay. The shop fixed an enormous exhaust leak plus a few minor ones all dealing with the gaskets. Yet I jumped in the car all nice and clean and BAM there was the smell again. Even w/ the windows up and no AC on at all. Just a closed cabin...
WHAT GIVES?! Any other ideas? Can my exhaust be leaking through the rear hatch somehow? I smell like a f'ing snowplow
Old Mar 22, 2007 | 01:32 PM
  #38
sentry65's Avatar
sentry65
the burninator
chicks dig snowplows
Old Mar 22, 2007 | 01:43 PM
  #39
Sean's Avatar
Sean
get a febreeze despencer installed ....rig it like a NOS system.
Old Mar 22, 2007 | 02:00 PM
  #40
Yancy's Avatar
Yancy
Hey bro. What shop installed the exhaust? What shop fixed the enormous exhaust leak and other leaks? Not that I can really remember cuz its been so long since I've had my car, but I vaguely remember a fuel smell to my car also, but i think that's common with the AAM RFS.
